DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 12th March 2014, 05:02 AM   #2681
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
Yes it would require a specially designed amp.
However take note of my earlier questions.
Without a phase spiltter you could run into dangerous conditions on the amp output in case of a fault on hot or cold pins. You would need to build protection circuits into the design, and perhaps these circuits would damage the sound more than the phase splitter?
Old 12th March 2014, 06:23 AM   #2682
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Protections are all a form of negative feedback, and as such, are adjustable so that it can't harm the signal, at some cost of reduced effectiveness for the negative feedback circuit. How difficult that might be is something that I cannot guess. It is over my head.
In this case, I think it would be both easier and more fun to use the dac's differential output as a bridge amplifier driver, resulting in a huge voice and a music suitable output. This, when successful, could not be apathetic at all, and that would be better than the small signal NE5532 or copies, at output. I wish that I knew how to do better than that, but I'm absolutely sure that we could and somewhat sure that we probably should try.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 13th March 2014, 05:07 AM   #2683
Probably best discussed on the amplifier forum not here.
Old 2nd April 2014, 02:40 PM   #2684
esgigt is offline esgigt  Netherlands
Wink Back to the original topic
Power supply is 2x15vac... with 2x 15000uF/25V
Just made some minor changes to the 2496 dac power-supply:
- replaced the standard 7809 regulator by the ON-Semi equivalent (with bead on output wire)
- inserted a 2uH in the connection of the analog supply to the digital supply, thus creating a low-pass filter in conjunction with the 2200uF/100nF cap improving seperation of digital and analog supply.
I did not replace the 7815/7915, because of the frustrating hassle of de-soldering them and I did not want to cut them up...
Result:
- The sound-stage cleaned-up a bit more. Instruments gained some detail and separation.
- The high-hats are more defined, with that characteristic "tjsss" sound they ought to have, without any harshness. So a bit of "Audio Nirvana" ...
- Bass is still firm, but gained some detail
In short: A disaster for the vendors of ready built DAC's... for I won't buy one in the foreseeable future
Old 27th April 2014, 05:13 AM   #2685
pwh is offline pwh  United States
Anyone ever run into issues with the BrownDog adapter + OPA827? I've tried two adapters + 4 OPA827s, and each time I connect it up I get a 10V offset in one of the channels. Not sure if I've overheated the chips, I'm being silly with the adapter or something else.
Unfortunately I can't find the original board I had with my first two opa827s, so I'm not able to try to mix and match the opamps until I get two working channels.
Old 29th April 2014, 10:49 AM   #2686
Wieslaw Lipowsk is offline Wieslaw Lipowsk  Poland
Default WIMA FKP2 capacitors?
I need FKP2 caps for my DAC.
These are what I found, are they real Wima FKP2? These are thin and white, and not thick and red as the ones I have seen on BOM.
Old 29th April 2014, 09:33 PM   #2687
vulejov is offline vulejov  Serbia
Banned
I was wondering if anyone dealt with the analog part .. I'm threw out opamp as soon as heard first sounds, and put in a buffer that sounds much better..
In the meantime, I discovered excellent LT1363/1364, I'm thinking now how to use them in this board..
So, analog filter on this board have everywhere 1K resistor, capacitors 3n3 and 1n .. and when you look at the AK4396 pdf they suggested completely different values , closer to the sense..
Old 29th April 2014, 09:42 PM   #2688
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Welcome on board
See this post.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 29th April 2014, 09:44 PM   #2689
Nosian is offline Nosian
hi Dario,
what happend to your AK4399 project? never came up with a BOM!
Old 29th April 2014, 10:42 PM   #2690
Banned
Originally Posted by ClaveFremen View Post
Welcome on board
See this post.
OK, what is advice?
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
