DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 18th November 2013, 01:05 PM   #2601
mllum is offline mllum  Malaysia
"for the usb i2s adapter, there are a few options that use asychronous operation.
diyink cm6631a - isolation"
Hello Tofurky,
I too would like to try the I2S connection between my CM6631A usb adapter and the AK4396 dac. However I am unable to figure out how to make this I2S connection.
Your kind assistance in this matter is kindly sought.
And with this arrangement would the CM6631A/AK4396 support output format 24 bit 192 khz.
Thank you very much.
Old 19th November 2013, 03:09 AM   #2602
Hello Tofurky,
I too would like to try the I2S connection between my CM6631A usb adapter and the AK4396 dac. However I am unable to figure out how to make this I2S connection from the 5 points on the CM6631A board to the AK4396 board, including the setting of the clocks to the appropriate frequencies.
And with this arrangement would the CM6631A/AK4396 combinatiom be able to support output format 24 bit 192 khz.
Old 19th November 2013, 04:01 AM   #2603
tofurky is offline tofurky  United States
hi mllum,
i haven't yet decided on an adapter or modified the dac. however, i did check the output clocks of one cm6631a in particular (the diyinhk model) and compared them to the datasheet; all sample rates appeared to be supported, including 192khz. at least with the cm6631 (non "a" model), it only does 16bit or 32bit. i think if you send a 24bit stream, it is padded with zeros by the driver, which are then truncated by the ak4396 back to 24bit.
regarding the physical connections to the dac, the first step would be to remove the 4 resistors between the cs8416 and the ak4396.
then, ground would connect up wherever you can find it. personally i think removing the capacitor labeled C28 on the attached image would be a good way to do it. you may want to double check the image because it's untested
also attached is a schematic of the ak4393 version of the board; but i believe it's nearly identical aside from the different dac chip.
-matt
edit: i think it might just be the firmware on the cm6631 i have that shows only 16/32bit; the datasheet shows 16/24/32bit, with the spdif outputs being limited to 24bit.
Old 19th November 2013, 04:18 AM   #2604
Thank you very much for this valuable information sir.
Old 20th November 2013, 12:43 AM   #2605
Peterma is offline Peterma  Australia
The diyinhk CM6631A usb adapter using I2S connection works, keep the links short.
Old 21st November 2013, 04:30 AM   #2606
Thanks Peter for affirming that.
But with what DAC does it work well and how is it connected. And also how is the clocks set to be correctly matched to output 24B192K audio between the CM6631A USB Adaptor and the DAC.
Thank you.
Old 22nd November 2013, 06:42 AM   #2607
Nosian is offline Nosian
Default i2S connection
this post is grate: #1531
Old 6th December 2013, 10:03 AM   #2608
terranigma is offline terranigma
terranigma's Avatar
Originally Posted by erin View Post
DiyAudio forum does not work that way. Once a post is made the OP cant edit it. So you might have to read a couple of pages.
A bit late but I just saw this post. As a feature, only first posts should be available to editing for owner. You could see a edit button right bottom corner of first post.
Old 10th December 2013, 06:27 PM   #2609
Fusion123 is offline Fusion123  Russian Federation
Send a message via ICQ to Fusion123
Could you please check shortcut between 17 and 18 pins of AK4396.
As per datasheet for pin 17 we are able to provide separate power line.
In that case shortcut between 17 and 18 is not required but the shortcut is there.
May be the best way to delete it?
PS I found it here
myelectrons.ru/high-end-dac-za-50/
page is in Russian please use google translate.
Old 18th December 2013, 02:44 AM   #2610
derekwyw is offline derekwyw  Hong Kong
Thanks for this thread, I did my version finally.
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
