DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 2nd May 2013, 11:16 AM   #2501
ttan98 is offline ttan98  Australia
Originally Posted by bismuth View Post
Yes, this is possible, I run mine like that.
See post http://www.diyaudio.com/forums/digit...ml#post3004419
I do not have the equipment for comparing jitter measure, but it sounds good to my ears ;-)
What did you use for USB I2S convertor, is it XMOS based chipset?
Old 3rd May 2013, 12:25 PM   #2502
bismuth is offline bismuth  France
I've tried Tenor TE7022l with success, now I'm using a WaveIO (XMOS). I think most I2S input will work with the AK4396.
Old 3rd May 2013, 01:00 PM   #2503
auxie22 is offline auxie22  Australia
Thanks bismuth,
I am glad to hear you have had success with the Tenor TE70221 as I believe that is the same chip as the one in the HA info.
Old 3rd May 2013, 03:06 PM   #2504
hotiron is offline hotiron  Scotland
hotiron's Avatar
Better off with CM6631 it goes all the way to 24/196khz.
This looks interesting too but I haven't tried it as of yet.
XMOS 384kHz high-quality USB to I2S PCB with ultralow noise 6.5uV regulator | eBay
If you give up easily Dont start!!
Old 3rd May 2013, 03:17 PM   #2505
hotiron's Avatar
Default AK4396 with CM6631 and discrete output stage.
The TENOR Chip works great but this is the dogs bollocks.
Need a bigger case now though!!
Old 3rd May 2013, 08:07 PM   #2506
SWIN is offline SWIN  Sweden
Anyone who have had sucess using the LME49990 op-amp in this DAC?
Open, clear sound, but all my attempts to get it working, ends up with it oscillating, and overheating.
A really nice and not to expensive choice, but it really got the jitters.
Old 3rd May 2013, 10:40 PM   #2507
@hotinron where did you get the usb converter board from? ebay?
us it this one from zoe_tsang
http://www.ebay.com.au/itm/CM6631-US...item2ec43091e8
Old 3rd May 2013, 11:02 PM   #2508
@hotiron would love to see more of your design looks great everything in one box
Old 3rd May 2013, 11:08 PM   #2509
Old 6th May 2013, 02:15 PM   #2510
Black Stuart is offline Black Stuart  France
Can anyone supply info on the output impedance of this DAC. I realise that there will be differences related to whether the build is as per the whole board or using direct out/tx out etc.
I have to fit a different value ,20K as opposed to 50K (shunted) in my hybrid amp to account for the low o/put impedance of my new phono stage @ 10 Ohm.
Black Stuart
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
