DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 14th March 2013, 10:28 PM   #2451
szczemirek is online now szczemirek  United Kingdom
Thank you Everybody! Problem resolved.
Old 16th March 2013, 08:23 PM   #2452
BikerBod is offline BikerBod  United Kingdom
I recently completed the modification of my MINI 2496 board with new parts as per the BOM published by clave freeman on this forum. I'm running the DAC balanced outputs through a balanced passive differential filter network then into a 6N6P SRPP buffering stage. Low pass filtering is essential with the AK4393 chip due to SPDIF type signals present on the audio outputs. After filtering this noise is no longer seen on the scope. The filter used is described in Thorsten Loesch's PDF availble on the web entitled "thermionic valve analogue stages for digital audio"
I was already amazed how good this little DAC board was before i modified it. Following the BOM upgrade the sound stage has opened right up. There is suddenly a great depth to recordings and i'm hearing subtle parts of the music that ive not heard before. Trebles are much cleaner, less grainy, bass notes extend right down to the floor as they should. I wasnt expecting such a radical improvement and i'm not sure what bit of the upgrade made the most audible difference considering it doesn't have any audio stages on board. My guess is that the better smoothing and filtering around the DAC and receiver chips has resulted in improved jitter.
My next upgrade will be valve shunt regulator (tubecad Janus based) for the 6N6P buffer and i might finally get round to fitting it all into a chassis!
Old 20th March 2013, 09:19 PM   #2453
Bizzie is offline Bizzie  United Kingdom
Ive built two of these mini 2496 dac's, one with a Broskie unbalancer and one following Clave Freemans BOM from a bare board and I think they both sound great but I prefer the valve output although the op-amp version has a lm4562 and I couldn't get the evox rifa smr caps so used x7 ceramic's instead I'm not sure how much difference this would make.
Old 29th March 2013, 05:37 PM   #2454
reg66 is offline reg66
i've read a bit about fuses blowing, are people talking about the fuse at the mains in switch, or have they installed a fuse somewhere else? (i have searched but i'm finding a minefield)
please provide links if anyone knows where to find details or even pics
cheers in advance
Old 29th March 2013, 05:47 PM   #2455
The fuse on the mains lead is only there to protect the cable, you should have a fuse before the transformer to protect the circuit I use a chassis IEC connector with a fuse inbuilt as this makes for less wiring and less chance of a mistake.
Old 29th March 2013, 07:19 PM   #2456
bcmbob is offline bcmbob  United States
As someone who reported some blown mains fuses, I have to report the last episode wasn't the fuse at all and I suspect some of the others weren't either. I checked the suspect fuse and it showed good continuity. What had happened was those tiny power screw terminals were loose and the joshing required to change the fuse was enough to reconnect the power lead. Can't say if this may have been a problem with other builders, but I plan to pull the PCB from the chassis, check the traces and try to replace the terminals with something more stable.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 31st March 2013, 07:06 PM   #2457
is the 7809 regulator meant to be stock, i can't find it on the BOM but just want to be sure. cheers
Old 31st March 2013, 07:39 PM   #2458
scrap previous entry, sorry
Old 31st March 2013, 07:39 PM   #2459
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Search for U4, in BOM it's clearly indicated as MC7809CTG
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 31st March 2013, 08:09 PM   #2460
yep, sorry clave. moment of madness!!!
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
