DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 22nd January 2013, 07:11 AM   #2381
gopib is offline gopib  India
Where is the optical input on the board...am I missing something???
Old 22nd January 2013, 07:23 AM   #2382
atupi is offline atupi  Romania
There is no optical input on the kit but you can add one if you want.
Old 22nd January 2013, 03:59 PM   #2383
I want to share my results in testing some good opamps:
OPA 827- sounds good but laks details a bit
LME49720- sounds really good, a lot of details becomes fatigueing
OPA1642-full bodied, really well balanced-my choice
Back to my DAC for more tests
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 22nd January 2013, 06:28 PM   #2384
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by atupi View Post
I want to thank to Dario and the others for a well documented BOM and mods.
You're welcome
Strange, in my setup OPA1642 if quite less detailed and full than OPA827...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 23rd January 2013, 05:45 PM   #2385
Default PLL filter mod
Reading carrefully CS8416 datasheet chapter 18.2.3 "Circuit Board Layout" recommendations regarding PLL filter today i have changed the three components with the recommended ones.
Also the Va pin was recommended to be decoupled closely to the CS8416 pin i have installed a 0.1 uf smd on the backside of pcb
These changes has been recommended for best jitter levels.
The results where obvious: more details on quiet passages, more voice presence.
I've added also for decoupling the two rails of opamp one 100nf quality film caps on every rail paraleled with the recommended elco's. I've seen this recommendation on every opamp datasheet.
Old 23rd January 2013, 11:20 PM   #2386
tofurky is offline tofurky  United States
hey,
i am going to build one of these based on bare pcb using the "full bom" google doc as a guide.
i like to try to get things from as few sources as possible, and mouser doesnt have a direct match for a couple parts.
C29,C24 are specified as 647-UFW1J470MED (nichion fw), but only 647-UKW1J470MED (nichion kw) is in stock
C5 is specified as Wima FKS2 22nF 50v, closest match is 505-MKS20.022/63/5 (Wima MKFS2 63V .022uF 5% 5mm)
C6,C8,C9,C21 is specified as Evox-Rifa SMR 100nF 50v, closest match is 80-SMR5104K100J03L4 (Kemet 100volts 0.10uF 5% 5mm)
any good mouser-sourced substitutes for C32,C33,C35 (Cerafine 10 uF 50V) and C38,C39 (Silmic II 100 uF 50V)? can i use all cerafine in place of the silmic?
thanks,
-matt
Old 24th January 2013, 12:08 AM   #2387
sorry if i wasn't clear, i'm wondering if those substitutions i came up with are appropriate.
also, i don't see what the spacing of the screw terminals is for ac/output/spdif in. any recommendations/mfg # here are appreciated.
-matt
Old 24th January 2013, 06:18 AM   #2388
For C24,29 i propose 647-UFG1H470MPM
Having in mind the purpose of C5 and C36 i propose to choose some ceramic caps.
like 80-C315C102G1G and 81-RDED72W223K2M1C1A
Instead of Evox Rifa 100nf i propose: 75-MKP1837410161F and instead of cerafines and silmics you can use Nichicons KZ.
All my proposals are to stick to mouser list.
PS. I hope Dario is not angry on me that i'm changing his BOM proposal
Old 24th January 2013, 12:44 PM   #2389
DrKnow65 is offline DrKnow65  United States
@Tofurkey
Be sure to check by the component value, not just the exact number on the BOM. I was able to find several of the "out of stock" components, I.e no stock on a capacitor in bulk packaging, but available in tape reel... Same capacitor, different package.
Hope that helps. Also check the status, some parts may be available with a very short wait.
Old 24th January 2013, 10:41 PM   #2390
thanks for the suggestions. still not sure about the screw terminals pitch though. standard .1" spacing? 5mm?
i read through dozens of pages of the thread and did some searches, but i did not see a clear reason why a 15v/9v r-core is suggested. 9v to a 9v regulator with a 1.3v dropout voltage? is this because with a small load, the transformer will actually output something significantly higher, like 12v or so?
i just bought this one: 30VA 30W R-Core Transformer 15V*2 9V*2 For DAC Preamp
and i read that even though PR9372 2.2kohm is on the BOM, 2.4kohm is actually the correct value?
thanks,
-matt
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
