DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 17th December 2012, 06:38 PM   #2331
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by killmister View Post
Treble and harmonics are much more respected with OPA 2604 or LM4562 for example but the dynamics is very flat, the sound is lifeless, it is not very musical, i can't listen as is !.
Several mods suggested in my BOM affect dinamic... LPF caps, regulators and opamp.
You may want to try OPA211 or OPA827 but first replace LPF caps.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 17th December 2012, 07:06 PM   #2332
killmister is offline killmister  France
The difference in the dynamic listening is such that it is not just a matter of taste. I do not understand. I may be trying an output transformer or srpp tube output. I do not like the op amp, there is no one in the signal path in my system except this one for the first time ! But, I'd like to understand. it annoys me.
Old 17th December 2012, 07:25 PM   #2333
Hi!
What kind of capacitors do you use for lpf section?
Old 17th December 2012, 08:00 PM   #2334
Reality first!
Just see it in BOM
Dario
Old 18th December 2012, 05:06 AM   #2335
Thank you. Good work !!
You use fkp. I have some styroflex in stock, i think it's better. I use styroflex in lpf section on my riaa preamp and these gave me the best result.
My dac is design for the ak4393 but there's a ak4396 on it! The lpf component values are those of the 4393 lpf section.
Old 18th December 2012, 12:47 PM   #2336
atupi is offline atupi  Romania
Well, after a succesfull MyRef Fremen project i'm coming along to you again with this project wich seems to be very successfull.
As i have no DAC now (my previous one has died and another project failed) I have ordered the bare board and the upgrade BOM from Distrelec.
@Dario: if i remember well you choose to use +/- 15V for opamp even in the upgrade BOM you put the 12 volt version?
I have ordered 15v version as i noticed some opamp working well closer to maximum voltage (LME49820 for example).
Greetings,
Adrian
Old 18th December 2012, 10:37 PM   #2337
Reality first!
Hi Adrian,
Upgrade BOM?
With a bare board you should order a full BOM...
Yes, I'm using 15V regulators.
Dario
Old 19th December 2012, 07:22 AM   #2338
Typing error. Of course i ordered the full BOM
Next year starts with a new project for me
Old 23rd December 2012, 07:51 AM   #2339
vinodt1347 is offline vinodt1347  United Kingdom
Hi, I have just built this and am blow away. This is playing from my SB Touch via DAC to Amp. I used mostly the standard kit from China but replaced 5532 to 4152, capacitors to more standard Nichicon/Elma and the regulators as suggested by Dario.
I think originally there was some harshness/edginess which is now replaced by a smooth sound. Merry Christmas..
Old 23rd December 2012, 07:27 PM   #2340
Max1410 is offline Max1410  Germany
does someone try high dimension (192 kHz) streams? Or it is possible 96 kHz only? For the AK4396 192 kHz is possible.
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
