DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 28th November 2012, 06:03 PM   #2281
Little_Eddy is offline Little_Eddy
Originally Posted by ClaveFremen View Post
It's simply because they're different products... my BOM is for the AK4396 MINI2496.
I understand but the function of the caps around the dac chip look similar, just that there is no filter cap on the 3.3V supply which is the one you increased to 100uF and changed to a solid type.
So would it be reasonable to assume the caps have a similar performance impact and that the Cerrafines for the 4 positions on the 4398 might be a good choice (3*10uF & 1*100uF), none of them bypassed as per the recommendations for the 4396?
I also ask because although your BOM is very well respected, ERIN seemed to favour solid caps throughout, and I guess many increased in capacitance value. So with me ordering a few 100uF LF caps and having a few spare thought these might be an equally viable alternative.
Old 28th November 2012, 08:47 PM   #2282
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by Black Stuart View Post
If I use Shottkies to build bridges are these the right values - 2A/1000V?
Hi Stuart,
anything above 50V is good, we're dealing with less than 25V...
I like a lot soft recovery ones, like SBYV27
I see that the Fischer heatsink is for using with the + reg. but none for the - regs, does that mean that the - regs generate no significant heat?
I would reverse... it's the positive one that needs additional dissipation since it supply also the DAC and not only the opamp.
My BOM can be used as an 'inspiration' for your DAC, part selection (caps, resistors, opamps, regulators) still apply, but for parts around the DAC chip you should do youself a selection (use sockets like I did), I've selected every single part by listening tests, I can't assure the same apply for CS4398.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 29th November 2012, 06:30 AM   #2283
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
Hi Dario,
If I use Shottkies to build bridges are these the right values - 2A/1000V? I have postioned all the components on the board (without soldering) and I see that I shall have to hotglue the 3 x PS caps to the chassis, only then can I build the Shottkie bridges.
Stuart
I hope you don't mind me suggesting 11DQ10 schottky diodes.
I have listened to many schottky diodes, and they all basically sound the same. As long as they have enough current and voltage to work in your circuit they will all work.
Personally I have also tried soft recovery diodes and find them to not sound as good as any schottky.
Old 30th November 2012, 11:22 AM   #2284
Black Stuart is offline Black Stuart  France
Is the value of the inductors critical - I ask because I can get values under or over 1.50uH from Distrelec - I don't want to have to order just a couple of components from another supplier and pay plenty in postage costs.
How are kit builders dealing with the LEDS since Along does'nt supply any kind of fixing for these.
Black Stuart
Old 1st December 2012, 02:58 PM   #2285
Whilst trawling for prices on op-amps I saw something interesting on Tamaudio - op-amps biased into class A - any comments? They (Tam) rec. 3.9K for the resistors - I can't see where the 1st leg of the 2nd resistor is soldered, any ideas?
Also saw the prices for op-amps on the Cimarron/Brown Dog site - $8 a pop for OPA827 and $3 for the adaptor, those are not bad prices and one would hope that they are genuine.
Stuart
Black Stuart
Old 2nd December 2012, 12:10 PM   #2286
Ignore the first part of my last post - check out Tamaudio and the two sites that they list - Headfonia, for the clear photos of just using Rs and Audiologica which gives a very detailed desciption of dos' and donts'.
Stuart
Black Stuart
Old 3rd December 2012, 09:06 PM   #2287
vinodt1347 is offline vinodt1347  United Kingdom
Default Top 10 Mods
Originally Posted by reg66 View Post
cheers again, clave. once i've done this (hopefully!), can u pm your paypal email, i'll buy you a few beers for your efforts with the BOM etc!
Can anyone please list out the top 10 mods which really make a difference or a critical for correct function.
Vinod
Old 3rd December 2012, 10:28 PM   #2288
reg66 is offline reg66
i don't know which are the top ten, but here's the link for dario's BOM, images and schematic
https://drive.google.com/?authuser=0...UzNzhjODI5MWRm
Old 3rd December 2012, 10:29 PM   #2289
also, here's images of the brown dog mod
http://www.diyaudio.com/forums/digit...532-a-223.html
Old 3rd December 2012, 10:57 PM   #2290
Reality first!
LPF parts and values, Nichicon LF, On Semi regulators.
OPA827 are 12$ a pop from Cimarron website.... BTW it's still a good price.
Dario
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
