DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 187 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 8th June 2012, 02:40 PM   #1861
erin is offline erin  Australia
The cs8416 datasheet clearly says you can use a ttl or cmos input
Old 8th June 2012, 05:32 PM   #1862
tamphist's Avatar
What is this chip?
It can play 24bit/192kHz so it can not be AK4393.
Fake AK4393, or AK4396 with wrong label?
Old 8th June 2012, 08:14 PM   #1863
In terms of PSU upgrades, one very simple thing I did was to remove the link from the +12V of the op-amp supply that feeds the A+5V and A+3.3V regulators and add in a separate +9V regulated supply, mimicking the other feed to the D+3.3 supply. It was easy to do as I had used two transformers to get the 15-0-15 & 0-9 feeds and there was a spare 0-9 feed available. You just need to cut one track and attach the new supply. Without this mod the +Ve regulator of the op-amp supply was getting overly hot.
Old 9th June 2012, 01:36 PM   #1864
fulvio is offline fulvio  Italy
Sorry, but is the AK4396 that has selectable TTL or CMOS input level (depending on pin 15 status); for CS4816 they say only:
" The CS8416 receiver input pins are not RS-422
compliant; the receiver input absolute maximum
voltage range is 12 V for the CS8413/14 and
-0.3 V to VL + 0.3 V for the CS8416"
(from AN339, Cirrus Logic Application Note)
Old 9th June 2012, 01:58 PM   #1865
I am talking about the cs8416. See the attached grab from the datasheet.
TTL input is ok
Old 9th June 2012, 02:03 PM   #1866
Originally Posted by tamphist View Post
What is this chip?
Old 9th June 2012, 04:47 PM   #1867
TTL input is ok
It is right, but only if VL (pin 21) is held at 5V; in Absolute Maximum Ratings they clearly specify: Vin MAX = VL +0.3.
In my MINI2496 board VL is held at 3.3 V.
Old 9th June 2012, 07:14 PM   #1868
ch33ta is offline ch33ta  Croatia
ch33ta's Avatar
Have to agree with fulvio on this one...
I read over the CS8416 datasheet countless times, and on page 27 you'll find this;
"The input voltage range for the input multiplexer is set by the I/O power supply pin, VL. The input voltage
of the RXP[7:0] and RXN pins is also set by the level of VL. Input signals with voltage levels above VL or
below DGND may degrade performance or damage the part.
So, it would be wise to keep SPDIF input voltage below the VL. Doesn't mean it won't work, but try it at your own risk...
Or you can put a simple resistor voltage divider, but it may not be the best solution...
Nothing to see here...
Old 9th June 2012, 08:50 PM   #1869
Thanks, I think I've fixed the problem using a compensated divider, that is a 33 pF capacitor in // with the series resistor of the divider.
In this way I can't see any difference in rise time before and after the divider.
By the way, I'm using my computer as a SPDIF source, and a 26LS32 balanced line receiver just in front of the SPDIF input of the board; in this way, without any transformer, I get more than 102 dB of S/N (20 Hz - 50 KHz band) at the audio output of the DAC board.
Old 13th June 2012, 03:56 AM   #1870
What do you guys think using this regulator...
GB for Salas SSHV2 regulator
hooked up like this picture? Will this have any improvements?
http://www.polkaudio.com/forums/atta...1&d=1333405930
Also using a large ferrite ring in socket wiring within the case, would that help?
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
