DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 5th June 2012, 03:02 PM   #1851
slider2828 is offline slider2828
Yeah I got the same thing for the coax and l r output.
Old 5th June 2012, 09:38 PM   #1852
F1 FAN is offline F1 FAN  Canada
There is a 75 ohm resistor across the spdif to ground.Maybe re check with meter in the ohm setting since it may indicate continuity with any thing up to 100 ohms or so.
Old 5th June 2012, 09:44 PM   #1853
bcmbob is offline bcmbob  United States
Thanks F1 Fan, that answer was also confirmed by Dario. I guess I'm O.K. Thanks for your reply.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 6th June 2012, 07:17 PM   #1854
For this DAC, does anyone have any pictures of their upgraded regulators? Does it make a difference? How do I do this?
Old 6th June 2012, 07:34 PM   #1855
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
The dac runs on +3.3v (digital side) & +5v (analogue) side. I'll be using STR (super teddy regulators) for each side. Just have to determine where to apply the voltage (and bypass the onboard regulators). Does it make a difference? (Not sure yet.) I'll let you know when I've accomplished this.
Old 6th June 2012, 07:51 PM   #1856
Yeah I have been reading about STR's, but I am no electrical engineer, just a hack.... Sooo I have no idea how to apply them correctly. But from my research, I have been hearing good things....
Maybe you can take a look at audio gd's stuff... They have some regulators that look interesting as well as their Op Amp HDAM stuff....
Old 7th June 2012, 02:05 AM   #1857
truepaul is offline truepaul  United States
This thread has lots of discussion of various regulators/PSUs that have been tried or proposed with this DAC. Here's some comments and build pics that I've taken notice of (I'm sure list is not complete, but others can chime in if they wish). Hope this helps!
1. Erin, who initiated this thread, identified early that the miniDAC could be improved by modifications to the PSU. “I think it needs a lot more than the supplied 1800uf reservoir capacitors. I intend to build an off board power supply with more capacitance for it. … 22,000uf on the analog power rails before the regulator…”
See Photos, page 5 [post 48]
See Summary at page 8 [post 78]
2. Dario/ClaveFremen prepared a very detailed BOM for swapping, adding and omitting various passive components. Overall view is, “If you decide to use my BOM it will sound good from the start, an alternate external power supply like Salas Shunt could go even further but only after you have optimized the rest, IMHO.”
From page 100 [post 996]
3. apoopoo999 -- Salas Shunt design ... Photos, Page 87 [post 862]
4. df_genius -- Salas shunts ... Photo, [post 667]
5. Sergelisses -- Salas shunt (and other... ?)
See photos [posts 813 and 1347, 1351]
6. simes123 -- photos [post 1015]
7. Discussion of Salas shunt regulator – see [post 1127] and others...
8. Nosian -- offboard-PSUs-to-charge battery, photo at [post 1188]
9. Giobax -- Salas shunt reg, pics at [post 1375]
10. Piersma -- Walt Jung regulators, pics page 172 [post 1716]
11. Dario/ClaveFremen -- simple shunt design, pics on breadboard [1620].
Old 7th June 2012, 05:02 AM   #1858
Thanks truepaul.... The simple shunt design would be exactly what I was looking for but it seems like geared towards the minidac, where I am looking for some shunt design for the big board.
Thanks for the awesome effort in showing me whats out there, but I wish there was a step by step on how to replace regulators and shunts....
Do you know if there is a direct way to replace regulators with maybe better regulators like STR?
Old 8th June 2012, 01:15 AM   #1859
Just confirming that the DAC works properly with the continuity between SPFIF "in" and ground. Really threw me off, but I'm still glad I double checked. Thanks again.
Bob M.
Old 8th June 2012, 08:44 AM   #1860
fulvio is offline fulvio  Italy
Hi, I’m going to add a SPDIF input selector to the 2496 DAC board.
Some of the SPDIF signals I want to input to the DAC board are 0/5 V TTL (i.e. the signals from TORX toslink receivers, output of balanced line receiver 26LS32 and the signal coming from a CD-ROM drive).
According to CS8416 data sheet, the maximum input level for SPDIF data is VL+0.3V, and VL is 3.3V.
I tried to use a voltage divider (after removing the 75 ohm resistor at the DAC board input) from 0/5 V to 0/3.3V, but this slows down the edges of the SPDIF data, producing a rise time > 50 ns (I suppose because of the input capacitance of the CS8416 that forms, together with the divider resistances, a low pass filter).
So the question is: did anybody tried to connect a 0/5V SPDIF signal directly to the CS8416 input (with VL = 3.3V) without blowing this IC?
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
