DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 175 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th May 2012, 05:46 PM   #1741
xslavic is offline xslavic  Moldova
wHAT do you say,its the forum where people develop with the help of others and improve the think they have,its DIY audio an we preffer the best not the Most expensive In US dollars or cheapes in Y en
Old 6th May 2012, 05:47 PM   #1742
i say that because i have allready cs2496 ,and i know its simple and Small ,but not enough for an enthusiast ,maybe Good for use in my truck
Old 7th May 2012, 08:04 AM   #1743
tomes is offline tomes  Malaysia
Originally Posted by ClaveFremen View Post
Well Bob... in fact an upgrade has been done... the MC7812/MC7912 are an important part of the upgrade BOM...
Hi ClaveFremen,
Is out of the topic but can i stack(parrallel) two nos MC7812 to get 2A for output?I afraid to try it may damage the dac.
Thank
Old 7th May 2012, 09:38 AM   #1744
Hi Tomes,
No, you cannot stack the MC7812 parallel to get 2A.
But why do you need 2A? The kit It uses 300-500 mA on the +12V side (only one side, the -12V does not). So just follow the BOM of Darius, and put a heatsink on it. That is enough.
And if you use a 2 x 14V transformer it get's less hot, than if you use 2 x 18V.
Old 7th May 2012, 10:32 PM   #1745
Originally Posted by jazzbear View Post
Proper power-supply decoupling Use a 6.8-F tantalum capacitor in parallel with a 0.1-F ceramic
capacitor on each supply terminal.
Having tried a couple of different op-amps and not seen the same heat problems with the op-amp or the power regulators it does seem to be specific to the THS4032CD so I'll give the decoupling caps a go.
In addition, the 0.1-F capacitor should be placed as close as possible to the supplyterminal. As this distance increases, the inductance in the connecting trace makes the capacitor less effective. The designer should strive for distances of less than 0.1 inch between the device power terminals and the ceramic capacitors - taken from THS4032CD datasheet.
That's a tricky task when using a surface mount device that's been adapted to fit a standard DIP socket. I'll see what I can do but maybe the THS4032CD isn't a good match for this application.
Old 8th May 2012, 09:12 AM   #1746
finally, made few pics of mine
2/3 has been done according to Dario's BOM.
Added salas for +-12v and +5v and Dario's shunt with BD139 (now it's ok, it shows 8.6v with 8.2v zener) for +3.3v
Digital part has 2x2200uf BC caps now and one 2200uf for A+3.3
Old 8th May 2012, 05:29 PM   #1747
hotiron is offline hotiron  Scotland
hotiron's Avatar
That mains socket is lethal!!! you really need to sort that out with a shroud or something. Your whole system is in danger of becoming LIVE!!!!!!!!!!
If you give up easily Dont start!!
Old 8th May 2012, 06:49 PM   #1748
@hotiron: What kit did you use? I see there is also a USB connection.
And do you have a schematics of the power supply and the phones amplifier with the volume control?
Old 8th May 2012, 07:55 PM   #1749
Sorry, I meant to ask @dtses about the schematics and the kit. Not hotiron.
Old 9th May 2012, 07:15 AM   #1750
the case is closed all the time, what is lethal? I don't see any point puting some insulation, correct me if I'm wrong....
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
