DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 1st May 2012, 12:30 PM   #1711
TheGimp is offline TheGimp  United States
TheGimp's Avatar
The THS4032CD (and all sm chips for that matter) rely on thermal conduction through the IC leads into the PWB to help dissipate power.
Since it is on a DIP8 socket and has wires replacing the pads, they probably do not conduct heat as well.
Put a heat sink on it. Seriously, tacpac a small piece of copper foil (or even heavy duty Aluminum foil) bent in an L shape to act as a heat sink. The opamp will stay cooler.
Old 1st May 2012, 04:58 PM   #1712
68Spider is offline 68Spider  United Kingdom
Originally Posted by haik View Post
You do not need on all three regulators. Only on one is enough.
The fact that the op-amp is getting hot, does not mean it is bad.
Agreed, the regulators at 35C and 45C and the op-amp at 50C are well within spec. But my experience of electronics is that higher temps lead to shorter working life.
Try to measure the temperature, and see, if it falls in the working temperature specification of the manufacturer. What we (humans) consider "hot", maybe not hot at all for some components.
I'd much rather spend a few pence on extra heat sink capacity than have something break and require time and have to spend pounds to fix in the future.
Old 2nd May 2012, 11:04 AM   #1713
dtses is offline dtses
Originally Posted by dtses View Post
I've got the parts for PS finally and curious now, is it safe to omit U6 at all, I mean if I stay with simple shunt from Dario (LM317+BD139+zener) could I directly feed CS8416 A+3.3 bearing in mind voltage peaks during switching on/off the dac?
hi Dario,
could I have piece of your advice once more please?
Regarding your shunt, if I replace both regs (U9 and U6), do I need to keep C21 and C34 caps?
Also if I replace only U9 (as I've done now), should it be connected directly to U6, thus omiting C14 & C38?
I've used 8.2V zenner with LM317 and got exactly 8.2vdc, so no need to add 0.6v calculating output voltage, am I right?
Old 2nd May 2012, 11:30 AM   #1714
Solve is offline Solve  Sweden
Solve's Avatar
I tried direct out to a pair of Monacor LTR-110 and cant hear
any differnces compared to OPA out.
Maybe my ears are bad or the rest of my eqipment is to cheap.
Run it thrue TA2020 and TABAQ speakers.
Does it need any load the transformer?
Just have it straight coupled now.
Music is the only art in real time....
Old 2nd May 2012, 04:57 PM   #1715
tonyho810 is offline tonyho810
Default Hole centres to mount board
Hello everyone,
I've ordered one of these boards and wondered if anyone has the dimensions of the mounting holes to hand. I'd like to get on with bashing some holes in a case whilst I wait for delivery.
Tony
Old 2nd May 2012, 09:36 PM   #1716
Piersma is offline Piersma  Netherlands
Piersma's Avatar
Default Finished MINI DAC
My finished MINI DAC with Walt Jung regulators for analog 5V, 3.3V digital and +/- 15V analog supply for the OPA2604 output filter.
regards,
Piersma
Old 2nd May 2012, 10:01 PM   #1717
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
If you mounted an elco in C3, probably not but it could sound better with them.
You should try.
BTW why do you want to replace CS8416 analog PS?
C38 can be omitted but why would you omit also C14? IMHO it's needed to decouple the opamp, particularly with an external regulator.
Did you replaced also U10, right?
No, there's something wrong, maybe you burned the BD139.
Can you post a schema of what you did?
My simple shunt has two sections: a current regulator (LM317 + current setting resistor) and zener+resistor+transistor as the real shunt.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 2nd May 2012, 10:06 PM   #1718
VT67 is offline VT67  Belgium
VT67's Avatar
@Piersma
Are those "Gold Mini Regulators"?
Old 2nd May 2012, 10:15 PM   #1719
Piersma's Avatar
@VT67
Yes, they are!
Old 2nd May 2012, 10:19 PM   #1720
VT67's Avatar
I also had the same idea of using those on my second board I ordered. (just to compare)
I just have to source the parts for the bipolar board though.
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
