DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 20th April 2012, 06:43 PM   #1681
j baldam is offline j baldam  United Kingdom
Originally Posted by tinitus View Post
no, not really
Sounds crystal clear to me, very helpful
Old 20th April 2012, 07:29 PM   #1682
truepaul is offline truepaul  United States
Default well, try this...
no, not really
Much of the discussion on this thread revolves around a set of documents that Dario has placed on a Google Documents page:
https://docs.google.com/#folders/0B-...UzNzhjODI5MWRm
[or see links Dario has placed, for example, page 113 , message 1125]...
By creating the Google Docs folders, we have a single place where you can find the BOM's schematics and pictures, and know that you're looking at the most recent updates.
Paul
Old 21st April 2012, 09:13 AM   #1683
hi a little of topic but not much.
I have received some parts for the DAC from Distrelec with an invoice.
There is no indication of how to pay, how do members generally pay.
I am in the UK
Old 21st April 2012, 12:04 PM   #1684
bcmbob is offline bcmbob  United States
In my upgrade process I unfortunately lost some thru-hole metal sleeves again.
The signal paths are not much of a problem and some of the grounds are repairable by flowing solder up the lead to the top of the board.
Will I be creating a problem by jumpering to the closest "valid" ground/- position on the bottom of the PCB?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 21st April 2012, 01:03 PM   #1685
OOPS! Corrected. Too early in the morning.
Bob M.
Old 21st April 2012, 01:05 PM   #1686
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
I'm sorry to hear that...
So the broken via is a ground connection?
If so I think it would be fine.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 21st April 2012, 01:22 PM   #1687
Hi Dario, Yes it is ground. The few signal pads that were lost can easily be fixed by scraping the trace and applying solder to reconnect.
....and thank you for not reminding me about the rework station you recommended several pages ago.
Bob M.
Old 21st April 2012, 05:46 PM   #1688
Hi Bob,
I've done the same, bent the lead around to the next ground point to fix.
I don't like the modern idea of two layer boards, give me the old ones with all tracks on the bottom any day
Old 23rd April 2012, 09:09 PM   #1689
haik is offline haik
In my amplifier (Yamaha DSP-A1) there are some DAC chips. All of them are AK4324. That is a 1 bit DAC, 128 times oversampling up to 96 kHz. 24 bit, 8 x digital filter and SCF filter in the analogue part.
So what is a better solution? Keep my S/P DIF output of the CD player (and have the Yamaha process it), or use the mini 2496 DAC board (which I now installed in the CD-player), and use the analog output to the amplifier?
The Yamaha is already 12 years old, so is the technology. Or is the technology in the AK4324 chip still "acceptable", compared to the 2496 mini DAC?
Old 23rd April 2012, 09:23 PM   #1690
Gave up the ghost. Two re-do attempts was just too much for the PCB to bear. Got new board with SMD chips installed ($12) on the way - Air Mail.
Bob M.
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
