DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 18th April 2012, 06:31 PM   #1661
TheGimp is offline TheGimp  United States
TheGimp's Avatar
No it is a single channel device.
Old 18th April 2012, 06:54 PM   #1662
VT67 is offline VT67  Belgium
VT67's Avatar
If you take two, yes.
OPA627 is a single op-amp, NE5532 is a dual op-amp.
Old 18th April 2012, 07:50 PM   #1663
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by haik View Post
OPA627: 4$ on e-bay, including soldered on an adapter for SIL insertion.
At that price it's probably a fake...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 18th April 2012, 08:24 PM   #1664
TheGimp's Avatar
Has anyone tried the LT6234 low noise op amp in this type application?
http://cds.linear.com/docs/Datasheet/623345fc.pdf
It as around $4 in single quantities. Digikey has it but Mouser does not list it.
Old 18th April 2012, 09:07 PM   #1665
haik is offline haik
I bought the 2 x OPA627 at e-bay. $7.50 incl. shipping
1PCS Dual to Mono OPA627AU replace OPA2604 NE5532 TL072 | eBay
It will take a month or so, but at least I will have time to get used to the new sound of NE5532, and then when I change it to the OPA627 I can hear the difference.
Old 18th April 2012, 09:43 PM   #1666
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I am listening to my new Jensen output transformers.
Compared to the capoutput I had before the bass is more tight and the treble is very detailed,great midrange.
I think I have to dampere the tweeter a db or 2.
Regards Åke
Old 18th April 2012, 09:49 PM   #1667
Reality first!
Maybe would be better to add a proper LPF filter to the dac...
Dario
Old 18th April 2012, 10:12 PM   #1668
Ryssen's Avatar
Yes,right now I have no filtrering at all..
Can you suggest such a filter,preferable on the secondary.
My F3 has an inputimpedance of 47K.
Regards Åke
Old 18th April 2012, 10:36 PM   #1669
Reality first!
Sadly I don't know how to correctly design it...but I guess you can try with a series resistor of 12 kOhm and a 470 pF shunt cap.
But probably a buffer after the filter is needed.
Dario
Old 18th April 2012, 11:23 PM   #1670
TheGimp's Avatar
I just got finished simulating the LPF on mine, -3dB at 90KHz which is ok for 92KHz bw, but I'd like to roll of starting around40KHz.
The recommended filter in the manual won't be difficult to patch in and should sound better as the -3dB point is around 49.2Khz.
At least it simulates better.
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
