DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 160 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th April 2012, 10:38 AM   #1591
bcmbob is offline bcmbob  United States
Bill,Are you using a "dim bulb" tester in your setup rig?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 12th April 2012, 11:28 AM   #1592
Reality first!
ClaveFremen's Avatar
Originally Posted by idjoel2000 View Post
hey Dario, can we see some pictures of your DAC after the shunt regs mod?
I've yet to try it... so no pics
Maybe this WE
it just seems with all that components, it seems a little pushing it to mount them all on the board
I think that an external PCB is needed.
I'll start trying it on breadboard and if it works as intended I'll probably make a PCB.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 12th April 2012, 11:51 AM   #1593
billo44 is offline billo44  United Kingdom
billo44's Avatar
I did use a dim bulb tester in line when I first tested the transformer before first plugging it into the board. The bulb never lit up at all and VAC outputs all seemed fine.
Very good advice though, and I will put the dim bulb safety factor back into the mains AC power supply line right away.
Thanks for the reminder.
Bill
Old 12th April 2012, 04:25 PM   #1594
I stumbled across this unit this morning. Has some interesting info at the design link on the page. Has anyone tried it?
S/PDIF Bridge | USB to SPDIF cable | USB DDC
Bob M.
Old 12th April 2012, 05:00 PM   #1595
Have you seen the price? $450?!?!
Old 12th April 2012, 05:50 PM   #1596
Hey, "It's only money!" Right?
That's one reason I wanted someone else to try it.
Bob M.
Old 12th April 2012, 06:22 PM   #1597
Maybe this WE
Hi Dario ,
What about capacitors in your shunt reg ?
Serge
Old 12th April 2012, 06:25 PM   #1598
Reality first!
Hi Serge,
the idea is to re-use the ones on board.
Dario
Old 12th April 2012, 06:53 PM   #1599
VT67 is offline VT67  Belgium
VT67's Avatar
My kit finally arrived
Old 12th April 2012, 11:05 PM   #1600
My kit arrived also (1.5 weeks from Singapore to the Netherlands).
I have some questions:
* The supplied resistors are 1% versions. I want to change them to a metal film 0.1%. Is that a good or bad idea?
* The smoothing capacitors (2200 uF) are made by Toshiba. No other markings on them. Should they be changed? Can any capacitors (like
10.000 uF, Philips or Panasonic) be used? The little ones (220 uF) are made by Nichecon FW types.
* I will replace the supplied L7812 by MC7812CTG
* The 100 nF capacitors are orange, drop type. No further markings. Also other capacitors are square, white or blue. No markings. Should or can they be replaced by sibatit capacitors?
* The 10 uF capacitors are gold marked, "W6C PET" marking. Good enough? Or tantalum is better?
* On the PCB I see some very small holes, and no marking on them. Are that VIA's to the other plane (bottom / top)
Haik
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
