DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 11th April 2012, 03:19 AM   #1571
billo44 is offline billo44  United Kingdom
billo44's Avatar
Originally Posted by billo44 View Post
All seem OK as per attached picture (small print sorry).
Just to point out the picture in my previous post is from Dario with my measured values annotated. It isn't my board.
If you click and then click the full size button bottom left it is readable.
Thanks everyone.
Bill
Old 11th April 2012, 05:40 AM   #1572
apoopoo999 is offline apoopoo999  United States
Thanks everyone.
Bill
Did you try putting back the 5532? I managed to kill 1 ak4396 and 1 ak4395 so youre not the only one
Old 11th April 2012, 06:42 AM   #1573
dtses is offline dtses
Originally Posted by ClaveFremen View Post
No, Salas shunt is for sure superior.
I think that probably a Salas shunt is overkill since opamps have high PSRR, while in a simple discrete circuit, like the DCB1, PSRR is much lower.
do you mean that there is no point and it doesn't worth to make separate salas just for opams (ex. some simple headphone amp or opamp output of CD player, etc). I was wandering is it ok to use your shunt with other regs - 7808-7812 or add some variable R to LM317 version?
Old 11th April 2012, 08:21 AM   #1574
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Bill, the values around the 9V regulator seems way too low but it shouldn't be a problem...
Now, apart no analog output, the leds behave correctly?
Not as a general rule.
Probably a Salas shunt would sound better than my shunt even with opamps but I suppose difference wouldn't be much thanks to opamps PSRR, IMHO.
But I didn't any direct comparison.
It's not clear... do you mean using 78xx instead of LM3x7 in current sources?
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 11th April 2012, 08:52 AM   #1575
50AE is offline 50AE  Bulgaria
My AK4396 chips have arrived today!! Hopefully tonight this DAC will be singing! This is what I did yesterday:
http://store.picbg.net/pubpic/83/FF/...98d54483ff.png
http://store.picbg.net/pubpic/D2/89/...1f2d6dd289.jpg
Old 11th April 2012, 09:22 AM   #1576
bcmbob is offline bcmbob  United States
Bill, did you start with a bare board or modify one that was previously assembled and functioning?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 11th April 2012, 10:13 AM   #1577
hi Dario,
just small improvement over existing opamp PSU in another diy dac (WM8740). As there is no place in the box for another salas shunt, your mod looks very nice.
The regs are 7812 & 7912, so I thought whether could I add marked part (att) between reg and cap? Is there any calculation for R104 & D105 or it's already done in accordance to BD139?
Old 11th April 2012, 10:57 AM   #1578
Reality first!
No, they replace completely the 7x12s.
And you shouldn't omit the LM317 CCSs... you can replace them with current setting resistors but you loose 50% of the performace improvement.
You must choose the zener voltage (Vout = Zener voltage + 0.6V) and size the current setting resistors R101/R201 (1.25V/R=Iout + 15mA).
R104/R204 are sized for a 500mW zener.
Dario
Old 11th April 2012, 12:11 PM   #1579
haik is offline haik
Originally Posted by bcmbob View Post
Billo - A shot in the dark - I had a very strange problem when wiring my JC-2 pre (yellow board). If both 0V wires were connected to the PCB the unit would not function. After combining them in a terminal block and running a single wire to the board, everythings works. Makes no sense to me ( I was going to post about it) but believe me, it was the only way I could get the pre to work.
Might be worth a try. In the photo the Lighter Note is also powered by the same toroid, but the problem was there even when that circuit was not involved.
Hi Bob,
It might be that you made a simple mistake. I see the cables (for secondary voltages) are same color. The secondary windings are actually polarized.
Not like positive or negative, but they have a "beginning" and an "end" of the winding. It does not matter how you connect them, as long as the cable to the center point of the pre-amp or DAC have two cables.
One should be "winding 1 END" and the other should be "winding 2 BEGIN". The beginning of a winding is often shown with a dot or a marking.
If you do that wrong, then they compensate themselves, resulting in 0 V (or very close to zero). If that happens, swap two cables from ANY winding.
Old 11th April 2012, 01:25 PM   #1580
Sergelisses is offline Sergelisses  France
Hello Dario ,
I would like to check your Shunt reg on the AK4396 5v Ana ,i have a question about the BD 139 .
Can i replace it by an equivalent smaler ?
Serge
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
