DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 13 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 4th June 2011, 05:22 PM   #121
syklab is offline syklab  Mongolia
Originally Posted by evangelion1999 View Post
Good friend
Where can I buy your DAC? does it comes in full kit?
Old 4th June 2011, 06:43 PM   #122
MrSlim is offline MrSlim  Canada
Here are several:
NEW Hi end DAC 24 BIT 192K HZ AK4396 sc | eBay
Assembled DAC 2496 (AK4396) CS8416 DAC Board 24BIT 192K | eBay
Assembled DAC 2496 (AK4396) CS8416 DAC With Transformer | eBay
depending on your skill level
Old 4th June 2011, 08:36 PM   #123
terranigma's Avatar
Since that AK4393/6 dacs are analog balanced signal out dacs, I suggest you to trial avoiding analog/opamp section with tapping analog L/R channels directly from pins. You have to add dc blocking cap if you will tap unbalanced signal from + pins and analog ground.
Blocking cap type and value can be determined during tests. I think 2.7 uF or greater would fit. You have to tap analog ground somewhere close to dac chip.
Old 5th June 2011, 02:39 AM   #124
erin is offline erin  Australia
Originally Posted by YohY View Post
I've not heard the AKM4393-based dac so you are in a better position to comment on their differences than I..
Just remember that I was comparing a modded board to the stock standard board. After mods the AK4396 might come out the winner.
Old 5th June 2011, 03:34 AM   #125
Seems like these guys don't ship or sell to Hong Kong, wonder why?
Old 5th June 2011, 08:48 AM   #126
YohY is offline YohY  United Kingdom
I refer to my previous post ;
..and all this without the components being burned-in & the standard NE5532 o/p chip in situ ?
So far, I can tell you this of the Calyx dac vs my AKM4396/opa627
..the difference is not Night & day !
And later, there'll be a pair of Sowter 9545E in place of the opamp
Old 5th June 2011, 10:26 AM   #127
Originally Posted by awpagan View Post
The AK4393/5/6 are all interchangable
The AK4395 has a better filter
Allan
Allan - Does the 4395 really have the better filter compared to the 93 / 96 ?
Erin - have you had similar experience of this ? I'm willing to accept that a new/higher chip may not necessarily lead to better SQ.
-Andy-
Old 5th June 2011, 07:25 PM   #128
Have you tried emailing them? It's odd because the first one says their location is Hong Kong, and the other two say China..
Old 5th June 2011, 11:22 PM   #129
-Andy-
Andy, I have no specific experience with this other than hearing the AK4395 in a Metric Halo ULN-2, which sounded very good.
Old 6th June 2011, 10:24 AM   #130
Default AK4395 Vs AK4396
Was the CS43122/ 4397 implemented the same way with EQ processing, digital level control etc ?
Allan
Ok, so I've pulled up the data sheets for the AK4395 / 4396:
The 4396 goes one step further in adding DSD (direct stream digital) functionality (see - Direct Stream Digital - Wikipedia, the free encyclopedia)
Although the AK4395 chip only goes up to 192khz sampling frequency, it appears to have better specs concerning the 24bit filter compared to the 4396 ;
__IC_____________Ripple__________Attenuation
AK4395_______+/- 0.0002db_________110 db
AK4396_______+/- 0.005 db__________75db
I accept specification differences may not always translate thru to real-life experience, but in this instance it could explain the 4395's increased SQ and Allan's conclusion.
I'm ordering an unpopulated pcb an a separate 4395 ic to check this out for myself. If it can give more spacial cues & depth as previously described, then I'm all for it
-Andy-
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
