DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 25th February 2012, 10:20 PM   #1261
50AE is offline 50AE  Bulgaria
@ggetzoff, where did you see 1k value?
About the resistors, I only changed anode and cathode resistors. 150R cathode for the Broskie and 150R cathode again for the anode follower. B+ is 220V, anode resistor 11k.
Old 25th February 2012, 10:24 PM   #1262
hotiron is offline hotiron  Scotland
hotiron's Avatar
pins 17 and 19 measure .02V (8416) surely this cant be right !? 47K should be pulling these pins high!! Duff chip??????
If you give up easily Dont start!!
Old 25th February 2012, 10:59 PM   #1263
hotiron's Avatar
Could someone measure a working DAC please, the 2 47k next to L1.
Old 26th February 2012, 06:54 AM   #1264
hotiron's Avatar
No Worries I've got it working now. It was a Reset problem.Sounding great.
Old 26th February 2012, 11:47 AM   #1265
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
The Unbalancer
Here's Broskie's schematic for VOUT usage and the link. Great article BTW.
File Type: png Unbalancer%20DAC%20V-out%20Schematic.png (51.3 KB, 864 views)
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, DCB1, VHEX + USSA-5
Old 26th February 2012, 01:15 PM   #1266
jef9200 is offline jef9200  Belgium
Hi all,
here is my version. Modified with the BOM, and transfos output. I use Jensen JT11-P1.
4X 470r carbon resistor, 2200pf mica in // (filter 70khz), and 13k srie with 620pf between hot and cold on rca (anti-ringing, Jensen data sheet).
Sound is fine..
Before, i use caps output, but sound was no as good. No good bass.
Old 29th February 2012, 06:01 PM   #1267
PsychoDogBeast is offline PsychoDogBeast  United Kingdom
Hi there all
Ive been skim reading through this great thread over the past couple of days, theres so much information to take in though.
I have purchased a pre-built DAC of fleabay in the black and silver aluminium casing, it took just short of 4 weeks to arrive and is a great bit of kit.
I have changed the op amp to a 46xx version and it sounds really good through my Sony APM 22ES speakers and home built power amp, unfortunately it seems to be lackin a bit of bass as said previously in the thread.
As the case is a bit short of space and i can only add components to the top side of the board due to the space constraints, can i ask what would be the best (and simplest) as im a bit of a newbie mods to get a bit more oomph out of the dac.
Im comparing it to my previous digital to analogue converter built into my Sony 2400ES home cinema amp and my source is a squeezebox playin flac files.
best regards and many thanks in advance.
James H
Old 29th February 2012, 09:24 PM   #1268
sterlingmck is online now sterlingmck  Australia
Wink Run in Time
Originally Posted by PsychoDogBeast View Post
Hi there all
James H
Hi James
These dac chips seem to take quite a while to settle down.
I would not look to change anything untill you have between 100-300hrs on the unit (I always wait for 300hrs)
Then if you still have an issue, follow ClaveFreman's BOm staring with power supply
Old 29th February 2012, 10:10 PM   #1269
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
And LPF filter caps...
They're only 2...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 29th February 2012, 10:14 PM   #1270
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I use output cap,but Im locking for a output tranny.
Is the bass good with the JT11-P1?
Regards ke
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
