DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 19th February 2012, 12:25 PM   #1241
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by swanny50 View Post
Wondering if anyone has tried The nichicon KZ in place of the Elna RFS, and ROA on the PS+ ?
I've tried also KZs and Cerafines are way better.
IMHO KZs are somewhat confused.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 20th February 2012, 04:29 PM   #1242
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Dario,
Looking at the suggested LPF agian in the AK4396 datasheet, why do you specify 1k R24-R34? Shouldnt they also be 2.4 (2.2k as you said is fine here).
Thanks,
Greg
Airline Pilot-If it's not Boeing I'm not going.
"Brain as big as a planet..." {sic} Nelson Pass
Old 20th February 2012, 04:51 PM   #1243
ggetzoff's Avatar
Dario,
disregard, I see that those 1ks are for the 4393-95. Sorry
Old 20th February 2012, 07:13 PM   #1244
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I´ve been listening some more,and I think this DAC sound a little darker then the CS4398.What do you others think?
Regards Åke
Old 20th February 2012, 09:02 PM   #1245
truepaul is offline truepaul  United States
Default Nichicon instead of ELNA?
Hi, I'm new to the forum, but have also made the plunge to build this AK4396 -- BOM-upgrade DAC. Greatly looking forward to it, probably will have it built by July !
I've learned a lot from reading this forum !! Thanks, all.
I don't know if it's harder to get parts in the U.S. !! I sympathize with Swanny50 in trying to source all the parts from one supplier !! So far, I've placed about 5 different parts orders with different suppliers, beyond the DAC kit itself, and still have a few components yet to get.
Why don't you order from Parts connexion instead?[/QUOTE]
Unfortunately, PartsConnexion doesn't stock alot of the basic parts listed in the upgrade BOM, and some of the "boutique" parts are simply disappearing (e.g., they were still listing the Riken resisters when I ordered, but unfortunately these are now gone, not to be replenished).
I wasn't able to find all the components at Mouser + PartsX, but after some thrashing about, I found another source -- Elfa Distrelec, which unlike others in the Distrelec universe, will ship to the U.S.! They seem to have a huge inventory, including the Evox-Rifa caps, for example. I haven't the time just now to test it, but I *think* you could get all the components with just two orders, by using PartsX + Elfa Distrelec.
Otherwise, use Mouser first, then fill in with PartX and Elfa Distrelec.
Best...
Old 20th February 2012, 11:28 PM   #1246
Reality first!
No problem
Dario
Old 21st February 2012, 04:31 AM   #1247
swanny50 is offline swanny50  United States
Default Thanks for the info on the Caps,and Parts conX.
Hey, thanks for the listening comparisons on the caps guys! I Will have to get some Elna Cerafines And Slim's! That PARTSCONNEXION website looks solid, thanks for the tip off. I should've looked harder. As far as removing and soldering the new parts whats the best approach ? I just got a 40 watt soldering pen and a hi Wattage Gun, I've never soldered or desoldered anything that I needed to be as precise, and also worrying of heat saturation of the parts! Last thing i need is to Burn up quality ordered parts. Hit me with your "Dont sweat the techniques", Your do's and don'ts of fine soldering please. All your info has been of great help, It keeps me from 2nd guessing everything until im in a tizzy!
Thanks again, Swanny
Old 21st February 2012, 04:56 AM   #1248
apoopoo999 is offline apoopoo999  United States
Just heat up the joints and rock the cap until it comes off, I would suggest you buy a desoldering pump from partsexpress to clean up the holes before you solder in the new cap.
Desoldering Pump 370-030
Old 21st February 2012, 06:43 AM   #1249
j baldam is offline j baldam  United Kingdom
Hi, buy a desoldering pump and hold it on the joint while you heat it with the iron.
Press the button and most of the solder will go up the pump.
Then you can heat up the joint and pull the cap if you need to.
Pulling a cap without a pump risks pulling the solder tab through the hole, past experince
Old 21st February 2012, 03:08 PM   #1250
ggetzoff's Avatar
Parts Connexion is a very good outfit to deal with. You can get basically get everything for the Dario's BOM at Mouser and Parts Connexion. The only thing Mouser doesn't have are the Evox-Rifa SMR's in polyphenylene flavor.
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
