DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 120 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th February 2012, 08:19 PM   #1191
Reality first!
ClaveFremen's Avatar
You welcome
I'm not an expert but there is a thing, sometimes overlooked, that is crucial: grounding.
For both performance and stability.
The better solution, IMHO, is to have all on the PCB, otherwise the only thing you can do is 'patching' ground like you've done.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 8th February 2012, 04:08 PM   #1192
Hi I have a little dot headphone amplifier.
If I were to use it as a preamp, would it be ok to use it direct from the A to d conversion point in the DAC instead of the current op-amp.
Old 8th February 2012, 05:32 PM   #1193
Furthe to my question above, would this be a better option, discrete opamp on a socket.Click the image to open in full size.
Old 9th February 2012, 03:36 PM   #1194
I didn't want to make a new thread so I have a question for you guys
I haven't had dac's in the past so all this is new but would you recommend the dac that this thread is about or this one High end DAC TDA1543 DIR9001 kit DIY WH-1 | eBay
I am quite comfortable with soldering and stuff, as long as it WORKS after I'm done :P
Also should I buy the R-core transformer for 24 usd off ebay as well? Or should I try to spot some suitable transformer locally?
Old 9th February 2012, 03:46 PM   #1195
Reality first!
Since the linked DAC has an external PS and probably coupling caps I would go for the MINI2496.
IMHO, absolutely yes!
Those R-Cores are very good.
Dario
Old 9th February 2012, 04:07 PM   #1196
Radian is offline Radian  Germany
Originally Posted by ClaveFremen View Post
Hi Serge,
those AKM DACs don't do the entire LP filtering on chip and they depend from the external LPF to give a straight frequency response.
Any LPF Filter is just degrading the sound of the AK4396.
If there is any hiss or harshness it is not from the Chip itself.
If the AK4396 has more the 100 hours of run in, any harshness has to have
another cause. Verified by Sendler, SunRa, Terranigma and me. We all use, or have used the AK4396/4395 with no active stage and no filter.
If anyone is experiencing otherwise I strongly suggest that it has more to do
with the impedance to the amp or whatever is used after the dac by the resistors than with roll-off.
Greets,
Klaus
Old 9th February 2012, 04:27 PM   #1197
Reality first!
Right Klaus !
Let's burn all these useless datasheets!
Manifacturers are conspiring to steal us good sound !
Dario
Old 9th February 2012, 06:44 PM   #1198
Right Klaus !
Clave,
datasheets of dacs are also suggesting OpAmps but who in his right mind
uses OpAmps for serious Audio?
I didn't have any CD Player or DAC on my bench that sonded better with opamps than with Tubes or direct out.
I know of at least 5 People inkluding me, who have done extensive work with
the AK4395/96 and all of us do not use the filter that is suggested by AKM.
At the end it should be our ears that decide what we use after the dac chip.
Most who complain about harsh sound from the AKM chips have not been
waiting past the 100 hour mark to do their mods.
Old 9th February 2012, 10:30 PM   #1199
Reality first!
Clave,
I'm not talking of opamps Vs discretes Vs tubes Vs trasnformers etc.
There is a single point:
The goal of every DAC, and associated circuits, is to give a flat frequency response.
AK4393/5 and AK4396 have different LPF stages which, taken alone, have different frequency response.
If we agree that the final result for both is a flat frequencey response AK4393/5 and AK4396, alone, have different frequency response...
So you can use whatever technology you want to do the LPF but if you want a flat frequency response you have to make a filter with the same parameters specified in the datasheet.
I know of at least 5 People inkluding me, who have done extensive work with the AK4395/96 and all of us do not use the filter that is suggested by AKM.
The datasheet for AK4396 specify a fc=125kHz, Q=0.692.
If you're using AK4396 with a different filter you don't have a flat frequency response.
Exactly.
I never talked about harshness but of unbalanced timbre.
I've heard it from the first listening and never changed with burn-in.
Also another forumer (Suburra) confirmed it.
We're 2 to 5. If it would have been a football match you would win...
But it's not so
Dario
Old 9th February 2012, 11:14 PM   #1200
F1 FAN is offline F1 FAN  Canada
What changes is the frequency at which the filter starts to attenuate.Therefore using the filter suggested in the 4393 datasheet with the 4396 will result in identical frequency response as if it were used with the 4393.
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
