DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 24th January 2012, 04:10 PM   #1121
pchw is offline pchw  United States
In one of my kits, I don't use opamp. In which case, I use one 0-12.6VAC transformer. I feed the 12.6VAC to the 2nd connector to power the circuit. Look back a few pages to see what I meant, I posted a couple pictures.
- Fred -
Old 24th January 2012, 04:24 PM   #1122
50AE is offline 50AE  Bulgaria
Great! Thanks for your help.
The coming week-end I'll start building the new enclosure for the DAC with 6N6P anode follower and 5C4S rectification. I don' have the choke and the power transformer yet, hopefully I'll get them these days.
I'll post pictures when done.
Old 24th January 2012, 05:09 PM   #1123
Sergelisses is offline Sergelisses  France
Originally Posted by 50AE View Post
I have a question. Except for the opamp, does the 15.0.15 V line powers anything else? I'm curious if I can just remove it, because I am going to do so with the opamp and put a tube output.
I can check myself, but I have the ideas now, and the DAC is enclosed. If no one replies, I'll disassemble it tomorrow and check it out. Or I will search for the PCB image.
Analogic +5v for AK4396
Analogic +3.3v for the CS8416
To improve the sound replace the LM1117-5v (Analogic +5v AK4396) by a SALAS SHUNT REG ........
Serge
Old 24th January 2012, 08:01 PM   #1124
Sounds very good! Thanks for the advice!
Old 24th January 2012, 08:27 PM   #1125
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by jimchan View Post
Thanks Clave + Erin for your efforts with this board. I have made most of the changes recommended, and really impressive performance.
You're welcome
The last change i have made was C40-43, 1500pF Wimas. Although this solved the raspiness at the treble, it also took away a lot of the realism and attach of the piano and other vocals.
1500pF? AK4393 or AK4396?
In this way you altered the LPF quite a bit, it's not a surprise that it sounds not so good...
I would search the raspiness in other places...
Exactly which parts are you using (capacitors and resistors)?
Originally Posted by NebuK View Post
The caps after the 1117 are same as also FCs, 47uF.
They can be problematic... do a favour to yourself and order from HiFiCollective some audiograde caps, shipping from UK is pretty low.
The + 15V is the source for DAC's analog 5V
I've done a Google Documents' folder with the last BOM, schematic, LPF schematic and signal and power paths and numbering.
Give it a look:
https://docs.google.com/open?id=0B-q...UzNzhjODI5MWRm
Sure it will...
In the next weeks I'll post a new shunt PS schematic, simpler than Salas one, which gave me great results with the My_Ref.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 25th January 2012, 07:47 AM   #1126
jimchan is offline jimchan  Norway
In this way you altered the LPF quite a bit, it's not a surprise that it sounds not so good... I would search the raspiness in other places... Exactly which parts are you using (capacitors and resistors)?
AK4396, 4562NA opamp, most other caps changed as advised, not touched C46,C47, not touched the resistors yet.
Changed C40-43 down to 100 pF now. Again nice treble, raspiness, but lose the bass.
I guess I need to use exactly 1000pF in this position, as you recommend (?) I have an MKP10 with this value I can try...(only have 1500pF FKP2 in stock ;-)
4396....4562NA....Silmic II decoupling....havn't touched any resistors yet.
Old 25th January 2012, 08:10 AM   #1127
Hi ,
Actually this very simple output stage give me satisfactions !!
But you need an input capa on the preamp or amp .......
Of course the +15 -15v is a SALAS shunt reg .....
Serge
Old 25th January 2012, 10:05 AM   #1128
NebuK is offline NebuK  Germany
Hey,
i've just taken a "couple" of macros of the board (warning, i've left them full-sized so you could zoom in and see a bit more, maybe):
dac-debug
Please don't laugh at my sometimes a little beginner~ish soldering. I've simply tried to stuff the most i could on the top of the board, maybe that was a mistake...
Anyways, i'd be really grateful if you could have a look at the board. Maybe i've done something very stupid wrong...
Also, i've noticed that receiving 96k as opposed to 44.1k audio seems to put a additional 4*C on the AK and ~7*C on the 7812.
@Fremen: I'm so grateful for all your comments and help, but still i somehow don't believe that my 1117-5v cap is the reason for this. I've put some el-cheapo cap in there which changed nothing. The el-cheapo *certainly* has enough ESR, if that should ever have been the problem. For my humble understand this rules the cap out, doesn't it? I'd rather suspect that maybe i've done something at the output of the AK wrong and it oscillates there (but nothing is audible...!) - also i've looked over the board *so* often trying to see whether everything was done correctly ;/.
Thanks again, all of you for your help. I'm really really counting on your further help with this! Thanks so much!
- Dario
Old 25th January 2012, 12:21 PM   #1129
Reality first!
OK, two problems:
  • You're still using the AK4393 LPF with the AK4396 so high frequencies are exacerbated, often resulting in harshness
  • The LM4562 is overly precise and detailed on high freqs so every minimum problem with them is thrown in your face.
The first thing to do, IMHO, is changing LPF's resistors and caps.
If, after that, highs are not as refined as you like you should also change the opamp.
OPA827 is as precise as LM4562 but it hardly get harsh.
Dario
Old 25th January 2012, 12:31 PM   #1130
j baldam is offline j baldam  United Kingdom
Hi any veiws on this for an output stage please.
http://www.ebay.co.uk/itm/Dual-chann...#ht_700wt_1037
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532Hide this!Advertise here!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
