Go Back   Home > Forums > Source & Line > Digital Line Level
Old 19th February 2011, 11:32 AM   #1
gabrielbecheanu's Avatar
Send a message via MSN to gabrielbecheanu Send a message via Yahoo to gabrielbecheanu
Default DAC with Four PCM 1704, PMD100, CS8412
Hi
A few days ago a friend of mine bring me a DAC with four PCM1704, PMD100 HDCD decoder and CS8412 receiver to listen. This DAC was bought from Analog metric..
The DAC have one S/PDIF and one AES.EBU input,
I made two power transformers but the DAC doesn’t work.
Any one has experience with this DAC?
Any suggestion?
Best regards
Old 19th February 2011, 04:11 PM   #2
Hi, check schematics of PSU part for this DAC. I have another model of DAC from this firm and found that they made very strange shematics in PSU - they use the same type of regulators chip to obtain (-) and (+) voltage. Thus, (-) voltage they derived with regulator placed in path to common "earth" on PCB. You need separate second windings (not common earth connection between them) on transformers for EACH voltage on PCB connector, even with eaqual values. After your previous attempt and before new connection, you need check all diods in PSU - some of them already could be broken.
Old 20th February 2011, 08:17 PM   #3
Thanks pionik
I just received the schematic diagram and i will check everything from power supply to output stage.
If some one made an improvement to this DAC i would like to know more about it.
I think that this DAC has more to show me after I will make him to work again
I have a DAC with CS4398 from Ebay, i will compare him with this four PCM1704 digital analog converter . I am so curios to see who will win the contest.
Best regards
Old 29th March 2011, 01:32 PM   #4
How did you get on Gabriel?
Would be interesting to see how it compared with your dac.
Old 29th March 2011, 03:15 PM   #5
qusp is online now qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
its not such a strange way to use floating regulators, as long as they inform the customer. in fact myself and a friend are utilizing the same technique with our dac psu. we are doing it for reasons 2 fold. the very high quality linear tech lt1764a regulator does not have a negative pole counterpart of the same extreme high quality, low noise and current capability and we can buy in bulk all the same chip to use throughout all 10 regulated voltages, simplifying layout and allowing bulk pricing on the regs
FS: DAC PCB (PCM 1704) made by Guido Tent bbakota2000 Swap Meet 14 8th March 2011 11:08 AM
CAL PCM1702 dac board PMD100 CS8412..$75 homemade Swap Meet 1 18th February 2011 12:33 AM
Need Help: Noisy output (Pin 14) of BB PCM 1704-based DAC dtm1962 Digital Source 0 2nd December 2010 10:37 PM
Hk Dac Pcm 1704 mfr Digital Source 16 22nd June 2004 07:14 AM
Page generated in 0.09113 seconds (74.58% PHP - 25.42% MySQL) with 11 queries
