DAC with Four PCM 1704, PMD100, CS8412 - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd August 2012, 06:45 AM   #11
gabrielbecheanu's Avatar
Send a message via MSN to gabrielbecheanu Send a message via Yahoo to gabrielbecheanu
Hi
I use CD8414 on this DAC
Best regards
Old 6th September 2012, 05:50 AM   #12
The PMD100 will cripple the sound of any dac. I've done enough comparisons with conventional DF chips in otherwise identical dacs to say with conviction that the PMD100 is an AWFUL chip, sucking the life out of any dac's sound. Makes things sound totally two dimensional & artificial. PMD200 isn't as bad, but I generally regard "HDCD" on a dac unit or player as a warning label.
Old 6th September 2012, 09:55 PM   #13
Thnaks for your information.
I made some research and i will try this RD 30 dac made by a Romanian Company.
I have a lot of HD music 24/192 and 24/96 and i tink more will come. Most of the DAC using this PCM 1704 are made specialy for 16/44khz clasic with DF1704 and DIR 9001 so 24/192 will never play.
Another thing that i want for my DAC is a system to display the sample rate that come in to the DAC.
I would like to know if some one use a four PCM 1704, wicth IV will be the best for this type of DAC, Tube IV or Transdformers or discrete stage or op amps?
Best regards
Old 6th September 2012, 10:55 PM   #14
fet audio got a DAC with dual PCM1794 that looks to be a realy good DAC.
FDA-1B.
Old 24th September 2012, 09:50 AM   #15
grunter72's Avatar
I think that gabrielbehceanu is searching a dac with pcm1704 not 1794.
Anybody know such a dac, possibly an open project with schematich?
Thanks.
Old 27th September 2012, 08:06 PM   #16
After many searches I decided to buy a DAC with 4xPCM1704, this is the DAC that I want to have it. http://www.diyaudio.com/forums/audio...converter.html
Why? Because in my opinion is the only DAC with PCM1704 open for all HD files including 24/192 kHz.
Most of the DAC found on the internet are made especially for 44.1 kHz signal using a DIR 9001 and DF1704. This is the most popular design for CD sample rate but if you want a DAC with PCM1704 for HD samples this is a hard task.
For the beginning I want to buy only the DAC and the display system (I like to see the sample rate that feed the DAC). For the IV I will use tubes maybe an Aikido product Unbalancer
Some people say that an IV with output transformers will be nice also; I would like to try also a transistor IV like in Nakamichi Dragon DAC. If someone has some advice for me in this future project I would like to know it. Before to arrive this DAC to me I want to know as much as possible about the IV, to have more projects to chose.
As soon I receive it I will post some audio test results, at the moment I use the most popular DAC on this forum the early version of the CS4398 DAC without upsampling, an modified ONKYO DX6850 with TCXO clock and a DUNE HD Max for HD saples. 6C33C SE amplifier
My frustration is about the 24/192kHz sample rates. The DAC don`t play this type of signal. It plays well up to 24/96 kHz.
Best regards
Old 27th September 2012, 09:04 PM   #17
grunter72's Avatar
Hi, I've found another interesting dac with 4 or 8 pcm1704 and also able to use 24/192 file Home - A WebsiteBuilder Website
I'd like to find a 1704dac with published schematics.
Old 28th September 2012, 07:33 PM   #18
Thanks grunter72
Because the DAC i chose is made in Romania for me is easier to communicate with them, so my first chose will be RD30, on the other hand I think that will come to me faster than other product from outside my country.
Before to decide which product to chose I made some research about the company that made them and many people say that the product made by this company are reliable and well done.
As soon I will get it I will inform how the product is and how will reproduce the music in my system.
Best regards
Old 2nd October 2012, 08:49 AM   #19
tubeclinic's Avatar
Default I/U conversion
Hi folks,
please read this basic article about I/U conversion prior to think about other DAC-chips.
The NITRO PROJECT a superior DAC
Please commence to this project after following the above link from mainpage.
Mostly bad sound derives from the fact, that all differential systems (OPA et al) at the I/U conversion treat even order harmonics as if they were common mode signals. This gives the well known "Solid State sound".
Best regards, Barbara
Old 23rd October 2012, 06:18 PM   #20
Hello guys
This week i will receive the new DAC but I have a small problem, maybe someone will help me with a good advice.
To this DAC I will connect a media player Dune HD Max via SPDIF connection but I want to use also my Onkyo DX 6850, This CD player has only toslink connection so I must put an XLR connector but I don`t know what is the best way to convert the SE SPDIF signal to the balanced AES/EBU signal.
I want to have both devices connected to the DAC, not to change the cable all the time between them.
Best regards
CAL PCM1702 dac board PMD100 CS8412..$75 homemade Swap Meet 2 5th November 2012 10:30 PM
FS: DAC PCB (PCM 1704) made by Guido Tent bbakota2000 Swap Meet 15 11th September 2012 09:38 AM
Need Help: Noisy output (Pin 14) of BB PCM 1704-based DAC dtm1962 Digital Source 0 2nd December 2010 10:37 PM
Hk Dac Pcm 1704 mfrimu Digital Source 16 22nd June 2004 07:14 AM
Copyright 1999-2017 diyAudio
