| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi
How do we connect the WM8804, for the hardware mode, and 16 bits I2S output mode, and with an external 12 mhz clock ? So which pin numbers would be connect where, like to the ground and to the DVDD, etc.. ? I've read the data sheet but I'm not sure about those connections. Thanx Paul Last edited by tessier; 18th February 2011 at 04:15 AM. |
#2 |
Here is one implementation: The S/PDIF Transceiver Module
www.hifiduino.wordpress.com |
#3 |
Hi
I've look at the web page you suggested but it's not easy to use it since I would use the WM8804 and SAA7220 with a TDA1541A Here is the schematic I've found on the web but with no explanations, any comments about it ? Thanx Paul |
#4 |
p 63 of the data sheet, the schematic from twistedpearaudio and the schematic above are very clear in the connections. All your questions are answered in the schematics.
#5 |
Hello
You can try to use maby these settings. WM8804 with TDA1541A, the setings are for 16 bit I2S and in hardware modes. But I am not sure abbouts the settings for the pin 5 and the pin 6 1--H (connect to the 3V3+ volt) 2--L (connect to the ground) 3--L (connect to the ground) 4--L (connect to the ground) 5--L (connect to the ground) ???? 6-- ???? 7--3V3+ 8--AGND 9-- 10-Xtal 11-Xtal (connect to a external 12 mhz clock) 12-Data output (connect to pin 3 of TDA1541A) 13- 14-BCLK output (connect to pin 2 and 4 of TDA1541A) 15-LRCK output (connect to pin 1 of TDA1541A) 16- 17- 18-DGND 19-3V3+ 20-SPDIF input Bye Gaetan Last edited by gaetan8888; 20th February 2011 at 06:01 PM. |
| FS: WM8741 DACs and WM8804 SPDIF chips | cs | Swap Meet | 4 | 16th February 2011 02:08 PM |
| WTB Wolfson WM8804 | dsavitsk | Swap Meet | 0 | 6th May 2010 02:02 AM |
| WM8804 with external clock? | teddy_pardo | Digital Line Level | 1 | 23rd September 2009 05:41 PM |
| WM8804 Software Control | fmak | Digital Source | 9 | 2nd January 2009 03:14 PM |
| Source for WM8804/5? | error401 | Digital Source | 4 | 12th May 2008 03:43 PM |
| Page generated in 0.08076 seconds (81.45% PHP - 18.55% MySQL) with 11 queries |
