| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Here is fft analysis for 5.2kHz at 0, -10, -13 (dBfs)
SR = 48kHz, 24bits Note the higher thd as the output level is increased. Level adjustment was via the dac's 32bit volume control. The load impedance was 20K ohms and a LM4562 preamp was used between the dac and the soundcard (Asus dx). Note: the LF noise is due to a slight earth loop. Last edited by VHF man; 10th February 2011 at 06:58 AM. |
#2 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
What's the vertical scale - 10dB per division?
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#3 |
#4 |
Sometimes a square peg fits a round hole just fine
some more information to accompany these measurements might render them useful to someone who doesnt own the AP. as it stands i'm not sure what to make of it. doesnt look too flash at all, but without something to gauge it by its not really that legible, to me
#5 | |
What I was trying to demonstrate here is that the 3rd harmonic makes an appearance near maximum output level. The thd looks to be up around 0.01% at 0dBfs but reduces to < 0.005% at -10dBfs and with only a 2nd order visible. Whether you think that this level of distortion is significant is a matter of opinion - but ftr using the same test bed setup I can't see any distortion from my power amp (at any non clipping power level) and into 8 or 4 ohm loads. |
#6 |
Interesting. I wonder if it's possible to repeat the measurements at the output of the dac chip.
#7 |
The issue is clearly analog distortion in the stages following the DAC. Not too severe, but it shouldn't be there.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 | |
jan didden
/Another new issue: Linear Audio Volume 3! |
#9 |
The input level to the sound card is the same for all 3 dac output level tests - as it appears on the analyser. I used a class preamp between the dac and the sound card to keep the sound card input level constant for the 3 measurements. Sure, the sound card and the preamp are contributing to the total distortion but the only parameter that's being varied in all 3 tests is the level at the dac output. FWIW the preamp + sound card thd contribution is difficult to measure - being so low.
#10 |
Banned
Interesting as I've seen the W4 being reported as being sibilant at times!
| Measuring AD1865 DAC2 | Nikon1975 | Digital Line Level | 1 | 18th November 2010 05:15 AM |
| OT: how can I measure THD of my amplifier if my sound card is 0,02% THD ? | ygg-it | Solid State | 1 | 13th June 2010 07:54 AM |
| WBT: Bel Canto DAC2 | iwok | Swap Meet | 0 | 31st January 2008 02:42 PM |
| Audio Note DAC2 | memorylane | Digital Source | 1 | 3rd October 2006 06:36 PM |
| Measured my Leach Amp distortion THD today | BrianGT | Solid State | 3 | 12th April 2002 08:03 PM |
| Page generated in 0.11256 seconds (78.33% PHP - 21.67% MySQL) with 11 queries |
