| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi all,
I'm pretty much a lurker here because the members knowledge is almost always above my head. Hopefully next summer I'll get a couple projects off the ground and actually be able to contribute to this wonderful site. I've got a non-functioning first gen DBX 3BX that when you turn it on (source going through or not) all of the indicator lights remain on and none of the controls have any effect. Accept the power button of course. I've used De-oxit cleaner and lube on all the switches and sliders and still nothing. The only thing I could find wrong inside is a bad tip33 transistor which I already got a replacement for from Digikey and will install Monday. I checked all the caps and diodes and resistors and found nothing else wrong. I also looked at the traces but could see no cracks or damage. Keep in mind, although I'm a merchant marine engineer, My knowledge of circuit boards is limited. I guess I'm wanting some opinions from the experts here. Could it just be a single transistor (the tip33) that's the sole cause of the problem, or is it likely that there are other issues? Here is a picture of the burned tip33: ![]() Thanks for the help, Rob |
#2 |
Sorry, if I posted this question in the wrong heading would a moderator please put it in the correct spot?
| Repair of DBX 3bx Expander.....Where to get it repaired. | oldheathkitphil | Analog Line Level | 3 | 21st March 2008 09:10 PM |
| Dbx 157 | amphead123 | Swap Meet | 0 | 21st February 2008 08:20 PM |
| dbx At P.E. | sdclc126 | Multi-Way | 24 | 23rd December 2007 11:26 AM |
| Stupid question about DBX noise reduction | webbcity | Analogue Source | 7 | 25th June 2005 01:36 PM |
| Page generated in 0.06977 seconds (70.26% PHP - 29.74% MySQL) with 10 queries |
