| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Seen a few products using a the crystek crystal featuring:
1. Low Jitter < 1pSec 2. Fundamental & 3rd Overtone Crystal Design Question: what is the best known frequency division circuit, specifically geared toward low jitter? Flip flops or PLL's. Looking for master clock solutions, also it seems like some DAC's have a built in PLL. |
#2 | |
This question is like a loaded gun.I would not dare to answer.The best way to put it is that to find your solution,you need to understand how digital circuits work, that is how a digital oscillator work and what is jitter. What is noise?.Next is the relationship of inherent/circuit noise to jitter.How does a PLL work,what are it's building blocks.How do you clean up a noisy signal.Then finally you look at the big picture which is your electrical circuit and why LRC (inductance,resistance and capacitance) affects circuit behaviour.After this you will have an apreciation of the difficulty of achieving timing accuracy and drift in an electrical circuit.Is absolute timing accuracy important or relative accuracy? What is available commercially cannot meet your needs? This imply you should know the problems and the ways or method to solve them. Most important,does it make a difference in performance sonically? Singa Last edited by singa; 2nd February 2011 at 10:30 AM. |
#3 |
There is a lot to be understood about many things. I'm just looking for some circuit ideas so I can build and implement a MCLK. Most DAC circuits that I see rely on sample rate converters to do the trick. Some seem to have some PLL type or other scheme built in to the DAC to reduce jitter. I've read somewhere that some flip flop circuit (ECL) based stuff was good for this kind of thing.
Lots of different techniques that manufacturers seem to use. I'm just looking for an alternative MCLK to experiment with in my system. |
#4 | |
conditioning features that standard clock offerings on the market do not have then you are not being realistic.If there were all of us would not be asking similar questions. It is a black art that normal people would not have the knowledge or experience nor the resources.If you are willing to investigate the art of PLL design you may reap rewards that people are too lazy to do.What I can suggest is that you visit semiconductor websites and troll the application notes and related info like web seminars there are tons of info that is useful for understanding the "secrets" of electronics.National Semiconductor is one such site.Just look for timing solutions or PLL. Good luck. ![]() Singa |
#5 | |
You might anyhow be interested in the concept of "reclocking". Unless your division ratio is exactly 2, reclocking eliminates the accumulated jitter added by a divider chain. It is kind of black magic (I have a couple of patents pending in this field). For a beginner, I recommend you try getting hold of the IEEE papers on 2/3-divider cells by Cicero Vaucher and friends. They do reclocking, give you a fairly arbitrary divider ratio and can be built in ECL. A PLL is preferably avoided, unless you aim for a non-integer division ratio. -- Greetz, MatchASM |
#6 |
A master has deigned to reply.Thank you MatchASm.
![]() ljfont ,you have been given a hint.Thank your lucky stars.Although you have not been handed a silver platter, the rest is up to you.Earn your stripes as they say. If you should succeed and you are kind enough then share itwith us?
| low jitter clock help needed | atcgreg | Digital Line Level | 10 | 9th June 2009 07:58 AM |
| Group buy for very low jitter oscillators | jwb | Group Buys | 2 | 27th January 2008 10:17 PM |
| Feeding the internal DAC's BCK directly with the player's low jitter clock | Bricolo | Digital Source | 8 | 13th July 2005 02:50 PM |
| Another clock idea for low jitter | Bernhard | Digital Source | 7 | 29th October 2004 05:05 PM |
| Low jitter crystal | bocka | Parts | 2 | 24th July 2003 09:53 AM |
| Page generated in 0.10067 seconds (79.62% PHP - 20.38% MySQL) with 10 queries |
