| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
ToyX project EQ Linearizer study case1 ...define band center frequency
I decide to DIY EQ Linearizer call X project. Because this step is ultimate diy in the end to tuning sound color from 10Hz to 20kHz. I had ever take a tube to be a EQ before but phase shift issue cause signal wave distortion and not time shift only. Simulate the band filter for correct phase shift issue first. Just follow FM , Cello do band sepration and do some center frequency modify. After estimate I Define The 5 band pass filter the C-Freq. will be 50Hz,250Hz,1KHz,4KHz,12.8KHz. images-1.jpg Center Frq. 50Hz of band1. Band1: 5~100Hz (5 pcs 20hz band pass filter inside 5~20,20~40,,80~100hz) Right Axis Center phase is degree 0 ,Left -Pi is -180 phase degree & Right +Pi is +180 phase degree @1 db band-width. images-2.jpg Coding a program to caculate help estimate for use big Cap. or Inductor to do L-Cfilter. images-3.jpg Center Frq. 250Hz of band2. Band2: 100~400Hz (5 pcs 60hz band pass filter inside 100~160,160~220,,340~400hz) Right Axis Center phase is degree 0 ,Left -Pi is -180 phase degree & Right +Pi is +180 phase degree @1 db band-width. images-4.jpg Center Frq. 1KHz of band3. Band3: 400~1600KHz (5 pcs 240hz band pass filter inside 400~640,640~880,,1360~1600Hz..) Right Axis Center phase is degree 0 ,Left -Pi is -180 phase degree & Right +Pi is +180 phase degree @1 db band-width. images-5.jpg Center Frq. 4KHz of band4. Band4: 1.6K~6.4KHz (5 pcs 1Khz band pass filter inside 1.6K~2.56K,2.56k~3.56k,,5.4K~6.4KHz) Right Axis Center phase is degree 0 ,Left -Pi is -180 phase degree & Right +Pi is +180 phase degree @1 db band-width. images-6.jpg Center Frq. 12.8KHz of band5. Band5: 6.4~19.2KHz(5 pcs 2.56K band pass filter inside 6.4K~ 9.86K,9.86k~11.52K,,16.64k~19.2Kband...) Right Axis Center phase is degree 0 ,Left -Pi is -180 phase degree & Right +Pi is +180 phase degree @1 db band-width. Mr211's Blog http://tw.myblog.yahoo.com/jw!9frLFy...oZT_geG5fC24WQ-- |
#2 |
Oder transformer...
34.67H / 10mA x2 pcs 10.26H/10mA x4 pcs 2.9H/10mA x 2pcs 9.65H/10mA x4 pcs 1.039H/10mA x2pcs 9.12H/10mA x12pcs 0.524H/10mA x2pcs 0.315H/10mA x2 pcs 0.471H/10mA x 2pcs 2.93H/10mA x20ps 0.695H/10mA x20pcs Big transformer images-7.jpg Mr211's Blog Mr211's Blog - Yahoo!????? |
#3 |
ToyX project EQ Linearizer study case2
Images-1.jpg Placment inductor of Band pass filter . Images-2.jpg prepare capacitor of band pass filter Images-3.jpg Do a rough structure placement. So far just one channel audio EQ structure. Mr211's Blog Mr211's Blog - Yahoo!????? |
#4 |
ToyX project EQ Linearizer study case3
images-8.jpg Tuning each inductor value for meet LC band pass filter images-9.jpg Finish each band pass structure images-10.jpg Test each band the frequency of drift . images-11.jpg Side view picture. Estimate EQ Linearizer outline (each channel ..two layer structure) and prepare drawing of EQ case. Mr211's Blog Mr211's Blog - Yahoo!????? |
#5 |
ToyX project EQ Linearizer study case4
images-1.jpg Hand make to Finish each band circuit by jump wire. images-2.jpg Finish EQ power connect circuit and do placement esitmate. images-3.jpg Test two bands EQ function together (by cascade). images-4.jpg Feed SG signal in band 4 for function test. images-5.jpg Measure output signal form band 5 and estimate circuit where need modify to meet design. images-6.jpg Band 4 top view. images-7.jpg Receive EQ box order from two month ago. This is front view with ten volume knobs. Each channel with five knobs to control EQ. images-8.jpg Inner picture. images-9.jpg Rear panel picture. Mr211's blog Mr211's Blog - Yahoo!????? |
#6 |
ToyX project EQ Linearizer study case5
images-1.jpg Put on L channel EQ module and check out the hole of screws images-2.jpg Assemble copper cylinder prepare for put on R chhanel EQ module. images-3.jpg Check out two channel EQ modules structure Meet design or not. images-4.jpg Another view. images-5.jpg Assemble Fuse,RCA connectors,Volume knob,power switch. images-6.jpg Finish wires jump between each band and volume knob. images-7.jpg Anothr view. Mr211's Blog http://tw.myblog.yahoo.com/jw!9frLFy...T_geG5fC24WQ-- |
#7 |
Sometimes a square peg fits a round hole just fine
wow thats some project, very impressive!!
not to be a downer, but could you not perform perfectly linear EQ function inside the box? I mean you are using a DAC as I have seen your dac project, so why not calculate EQ at 40-48 bit depth (or higher) inside waves diamond plugin with matching hardware acceleration? would be different if you were also seeking a cheap solution, or to colour the sound with distortion, but you arent. suppose of course this would not be as DIY |
#8 | |
Your guess right this a personal DIY. That's too many components in your audio gear system will effect sound feeling. Base this reason I hope to make a system could easy tunning sound is system. That's way I make a Analog EQ Linearizer. Another reason I had ever listen one Pre-Amp (have DSP EQ inside) before. sound feeling just loss 3D Sound field re-bulide become 2D feeling. Loss so much detail. I know DSP ability even 64bit...some time need do trad-off to design. Special is the filter design easy cause the small signal and second harmonic easy to get loose. My principle of audio gear just a 5Hz~20KHz total impedance match. So analog EQ linearize could easy to tuning signal level in the system. I beliving yr got exprince that's just chang a cable will chnage something in yr system. That's why Cello have palette and FM have new 268 re-amplifier to execute this function. Thay just re-bulid each record (curve of RIAA) form LP to CD. My person concept for just your reference. Aster Mr211's Blog - Yahoo!????? Last edited by asterkao; 6th February 2011 at 09:58 AM. |
#9 |
ToyX project EQ Linearizer study case.....6
images-1.jpg Finish analog EQ channel L connection and make each band test. images-2.jpg Left down coner is band 3 -1Khz,Right down coner is band 5 -12.8kHz. images-3.jpg Put on copper post for boost up analog EQ channel R module. images-4.jpg Lock screw for channel R module and finish wire jump. images-5.jpg Ten knobs look ..... How about... look familiar with someone? So far this project take me about one year. Just prepare into a phase of pre-test tunning sound color. Aster Mr211's Blog - Yahoo!????? |
| Anyone who have experience diy FM acoustic , Cello , Halco , Ayre amp? | bmpa | Solid State | 11 | 27th November 2011 10:39 AM |
| Old analog desk EQ mod | migs | Analog Line Level | 3 | 5th April 2010 08:23 AM |
| DIY biuld help | buga786 | Multi-Way | 0 | 12th December 2008 07:54 PM |
| I'm planning to biuld a sub | VEC7OR | Subwoofers | 14 | 30th August 2003 05:20 PM |
| Page generated in 0.14218 seconds (81.85% PHP - 18.15% MySQL) with 11 queries |
