Need advice on DIY DAC
Old 10th January 2011, 01:50 PM   #1
Crosstan is offline Crosstan
Default Need advice on DIY DAC
Hi to all, after doing some reading and research, decided to give DIY a try. Since I am TOTALLY new to DIY, seriously need some advice.
First of all, I am highly rusty with my circuit theory though I believe brushing up should not be too big a problem for me. But for a first project, thinking of getting DAC kits (just to build up some confidence). In this case, how much of circuit theory do I really need?
What equipment/tools will I need? I figured a soldering gun/station and a trusty multimeter are a must. Apart from that, do I need a signal generator and oscilloscope for troubleshooting/testing? If so, are there any economical recommendation (e.g. a more PC based solution with some hardware boards to be connected)?
Thanks in advance for all pointers shared.
Old 11th January 2011, 05:43 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Hi, If you want to build confidence and not go wrong by etching the pcb then
just buy a dac pcb or kit,I assume you have zeroed in your favourite dac.
A basic multimeter is all you need to check voltages.
Signal generator and scope even if you have them you will rarely use.
Unless you have ample funds.For a free and powerful PC scope/spectrum
analyser/Zrlc meter/signal generator, do download the 2011 beta version of Visual Analyser.Do a search as I don't have the url now.This is not shareware btw but
a full featured software by an Italian phd. holder.
English documents is in main directory after installation.Unfortunately the interface board articles are in italian anyway just looking at schematics is all you need to make one,so download them anyway as they are helpful.
Regards.
Old 11th January 2011, 08:45 PM   #3
josha is offline josha  United Kingdom
Hi, I started by building a DAC - a simple NOS with a USB interface, I forget the kit but it came with the USB chip already soldered on the board (surface mount). I then built up the power supply and DAC with the supplied components using just a soldering iron and some side-snips.
Don't forget the case though! I bought an aluminium box from Maplin (UK), a pot, a volume knob and a switch.
Tools used - soldering iron, side-snips, drill, metal file, a screwdriver and a multimeter. I think I salvaged the transformer from an old NAD amp. (you might find a de-soldering pump or ribbon handy, I did!)
It was a fantastic experience and sounded better than anything I had heard before, all up around 50ukp I guess.
Once you've built the kit you could start tweaking it and testing with a scope (I have a scope but I never used it, too busy using the DAC ;o)
I had little or no circuit theory before this but building the kit taught me loads, the nos dac (tda1543 I think) was simple enough and requires very little in terms of supporting components - I'm sure it's not the most sophisticated circuit in the world but you can easily experiment with PSU's, output stages etc etc once you've got a working starting point.
Hope this helps.
Josh.
Old 11th January 2011, 08:51 PM   #4
I remembered! Audio Workshop
I don't know if they're still shipping, I ordered a few years ago, nice kit though, you can clearly see the different sections (usb decoding, DAC, PSU) so you could always hook up the decoder to a different DAC or PSU in future.
Cheers
Need advice on DIY DACHide this!Advertise here!
DIY tube output in DAC - needs advice... jazzpeter65 Digital Source 71 3rd April 2011 05:46 AM
DIY tube/phono pre in the same case as my DIY dac? ben62670 Analogue Source 3 29th October 2010 09:46 AM
Any experience with this ebay-dac-kit?(searching a diy-dac) xTr3Me Digital Line Level 2 31st December 2009 12:07 PM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 10:41 AM
My first DIY DAC, advice needed mr_push_pull Digital Source 19 30th August 2005 05:16 AM
Copyright ©1999-2017 diyAudio
