| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I have been working on my Active Crossover DSP setup lately & have an issue that I would like to solve before I kill a speaker or two.
I am using MiniDSP as the crossover, this morning I accidently turned the DSP on while the amp was on & turned up high. The noise that came from the speakers was most unpleasant & dangerous. The MiniDSP is powered by two phone charges, I was wondering if I installed a capacitor between the charger & the DSP would this help with the problem should I accidently do it again. If it will, what sort & size capacitor should I use? David |
#2 |
The pops are most likely emanating from the output stages of the miniDSP unfortunately. You either need to be careful, or use muting relays.
#3 |
The noise was probably "digital hash" as the miniDSP locked on to its signal. The way to make sure it doesn't get through is to make a mute circuit. I don't know if the MiniDSP has a resistor in series with the output so put a 100R in series with the output, and use something like Project 104 - Preamp/ crossover muting circuit to mute the output. It may take some tweaking to operate on lower voltages.
You'll probably like the sound of your miniDSP better with a proper linear power supply. If you use a transformer with a pair of 9V windings you can get 12V to operate the relay and mute circuit and then regulate that down to the 5V the MiniDSP needs, with separate supplies for each channel. |
#4 |
#5 |
Thanks for the input guy's.
David |
#6 |
Use a Polyswitch on the speakers while your figuring things out to protect them until your ready. Cheap, fits in line on the + speaker wire, come in 6 values.
http://www.jaycar.com.au/images_uploaded/polyswit.pdf Jaycar Electronics - Search results poly switch Cheers George |
#7 |
It looks like a polyswitch won't protect from overexcursion, which is the main danger to speakers (especially tweeters) with an amplified pop/crack.
#8 |
Basically the CRACK came from (I think) the arch & surge that was created in the power point switch when I turned it on.
I have a Kingrex T amp, that causes a loud crack if I turn it on at the amp, but only a small crack if I turn it on at its power supply, which is full of capacitors. I was thinking the capacitor would absorb some of the surge, but I guess I would need a far amount of capacitance to do a good job. David |
#9 |
It's not the PSU, it's inherent in the miniDSP boards (and many other pieces of audio gear - RME FF400 and Sandisk Sansa Clip are misbehaving devices I own).
Read this for more on the miniDSP: MiniDSP - When minidsp close there is a ?kntoup? noise . - MiniDSP |
#10 |
A crack may be switch arcing or a different psu startup behavior than your T amp. You could spend a lot of time tracking it down, but since the MiniDSP boards are known to have startup/shutdown issues, mute relays are the solution that will do you the most good.
Of courser at less than a watt, it wouldn't hurt to leave it on all the time. Last edited by BobEllis; 8th January 2011 at 02:07 PM. |
| Gratuitous destruction | PeteMcK | The Lounge | 4 | 4th July 2010 02:56 AM |
| What the best way of stopping car rattles? | MikeHunt79 | Car Audio | 8 | 14th February 2008 05:53 PM |
| Stopping RFI. Mobile phone blips from speakers. | markiemrboo | Chip Amps | 9 | 13th May 2007 11:26 AM |
| stopping a ground loop through the power cord | Bama Slamma | Solid State | 9 | 11th May 2007 12:08 AM |
| There's no stopping now..... | Selexus | Chip Amps | 31 | 20th December 2004 07:16 PM |
| Page generated in 0.10779 seconds (75.63% PHP - 24.37% MySQL) with 11 queries |
