Balanced AES/EBU to/from optical S/PDIF - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 8th January 2011, 02:12 PM   #21
novec is offline novec  Norway
novec's Avatar
Send a message via MSN to novec
This would work for an output circuit, right? The coax pad is from Rane's notes, and I'm just guessing it'll work to connect the TOTX177 ahead of it.
I'll use gmarsh's 74HCT86 input circuit, but I'll skip the inverting gates and tie the return wire to ground so I can feed coax S/PDIF into the same input without any extra switches.
Old 8th January 2011, 03:17 PM   #22
RIP
Doesnt the transmitter require TTL level?
Old 8th January 2011, 03:24 PM   #23
novec's Avatar
That's what I'm not entirely certain of. The datasheet says TTL interface, with an active high voltage of 2-5V.
And just for the record, there's no requirement that optical out works when coax is connected.
Old 8th January 2011, 03:26 PM   #24
edwyun is offline edwyun  United States
No longer made but you can still find online/ebay & relatively cheap.
Core Sound — M-Audio's CO3 Format Converter & SCMS Controller and AES-EBU, S/PDIF & AC-3 cables
Old 8th January 2011, 03:58 PM   #25
RIP
At a glance it looks like it will work, but you can always change the pad scheme if it doesn't. Wiring in the transmitter before the second divider would probably work fine.
Old 8th January 2011, 04:57 PM   #26
novec's Avatar
That takes care of output. On second thought I'll ditch the idea of putting both coax and optical on the same input, so I'll use gmarsh's 74HCT86 circuit on the optical inputs with no more fuss.
There's an elaborate S/PDIF to AES circuit on epanorama (Bill's link):
Code:
                                           _
                  + 5 volt                | \
SPDIF out:          |                   +-|  O-+
                    _ +--4,7k-+         | |_/  |
              diode ^ |  _    |     _   |  _   |
       10 u (+)     | | | \   |    | \  | | \  |      100 n
O--+--+-||-+--------+-+-|  O--+--+-|  O-+-|  O-+-120 r-||-+----+-- 2
   |  |    |        |   |_/   |  | |_/    |_/             |    |
   |  +-||-+ 100n   _       2,2k |                       1 k   |
  75r               ^ diode   |  |     IC                 |    |   AES in
  ---              ---           |       _                    220r
                                 |      | \           100 n    |
                                 +--+---|  O---+--120 r-||-+---+--- 3
 Diode = 1N914 or 1N4148            |   |_/    |           |
                                    |    _     |         1 k   +--- 1
    IC = 74HC04 or CMOS 4049        +---|  O---+          --- ---
                                        |_/
I think I'll take my chances and tie return to ground and run coax straight to live, instead... Don't know if it might be a good idea to put some resistors in there somewhere, though - it'll be about a meter of balanced cable between the input circuit and Lynx inputs.
edwyun: Thanks for the tip, but I'm hoping that won't be necessary...
Old 8th January 2011, 08:26 PM   #27
novec's Avatar
Here's the finished input circuit. I hope I've done the XOR part right...
Balanced AES/EBU (SPDIF) input circuit (to DIR9001) novec Digital Line Level 19 24th May 2010 12:15 PM
S/PDIF vs. AES/EBU Calamaro Digital Source 23 26th September 2009 08:45 AM
S/PDIF Optical to S/PDIF RCA Replacement PrecisionAudio Digital Source 2 11th February 2007 09:35 PM
In - Out AES/EBU santosa Digital Source 1 26th July 2005 04:28 PM
DIGI balanced AES/EBU -> SPDIF Coax meta Digital Source 3 26th May 2003 05:51 PM
Copyright 1999-2017 diyAudio
