BUILD THREAD - A New Take on the Classic Pass Labs D1 with an ESS Dac - Page 62 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 9th May 2013, 05:55 PM   #611
qusp is offline qusp  Australia
qusp's Avatar
right, so somebody else can answer again, the question that has been answered over and over and over... that makes it sooo much better.
I finally managed to get the attachment to stick in the post on the previous page, its a calculator someone gave me many eons ago when I had no idea the importance of such things. you will need to plug in the values for impedance and capacitance.
it really is something you should learn how to do without the exel file though, it applies to every single stage where a capacitor couples a signal to something less than an infinite impedance, parasitics too. its a simplified calc, but if you are using a transformer, you have to add in the primary and secondary impedance of the TX and the winding ratio ie work out the reflected impedance, not as simple to solve as connecting the NTD1 directly to an amp.
btw: i'm completely aware that i'm abrasive, its deliberate in some cases that call for it...
Old 9th May 2013, 08:20 PM   #612
Rolle is offline Rolle  Denmark
Originally Posted by qusp View Post
I wont comment on the Broksie stage ...
Ok qusp - I guess we are in religious territory here ;-) no need to argue about that
Hey Anders Trentemøller - correctly spelled - just nitpicking back i saw him in live concert with another dane Michael Simpson a couple of years back. That was my moment of bass explosion. The roof went of the building - fantastic concert. Sorry for off topic
Old 10th May 2013, 01:29 AM   #613
qusp's Avatar
hehe yeah I knew I was probably spelling that wrong/lazily, good catch.
I saw him/them at 'Family' in Brisbane in 2007 ('the last resort' tour). its a pity that a couple of his tracks that would be almost perfect system tests and are otherwise quite well produced, with a decent amount of light and shade, actually do clip very slightly. the recording that is; Always Something Better (his remix) was EPIC live!
Old 25th May 2013, 12:21 AM   #614
pinnocchio's Avatar
Wow! This thing is easy to adjust! Really nice work Owen!
Now I have to double check/tweak AVCC /2 and adjust accordingly but the 1.65V initial test was no issues at all.
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 4th June 2013, 06:51 PM   #615
pinnocchio's Avatar
Here's a quick peek of my build... It is not the latest pics since I have added heatsinks to it.
Chassis will be done later. On a side note, has anyone modded an EXAU2I to add external power to it? If you have succeeded in doing so and it does make a difference in SQ please PM me.
I've already put in more than 30 hours of music and must say it is definitely the BEST I/V stage I have ever had for my BII!
Sounds really good
Ciao!
Do
Old 6th June 2013, 04:26 AM   #616
opc is offline opc  Canada
opc's Avatar
Thanks for the feedback and the great pictures Do!
Your build looks excellent... very clean layout and a good choice in the EXAU2I
I know from experience that combo sounds superb
Owen
Old 6th June 2013, 04:26 AM   #617
opc's Avatar
A new run of these boards is now available!
Please see the following thread for details:
http://www.diyaudio.com/forums/solid...ml#post3516741
Owen
Old 6th June 2013, 06:53 AM   #618
analog_sa's Avatar
Not easy. I did a partial job by lifting the two regs 1.2v & 3.3v and supplying external power. This leaves the front end still powered by USB.
Since using Ian's kit i have reverted back to full USB power as the improvement now is too insignificant.
Unless using Ian's fifo i would imagine the best thing for the EXA is applying external clocks and reclocking the outputs after the isolators.
Old 7th June 2013, 04:22 AM   #619
pinnocchio's Avatar
Owen
Thanks Owen,
I'll update the picture later on when the whole thing is in a chassis
Ciao!
Do
Old 8th June 2013, 04:33 AM   #620
Are in trouble: (
When Buffalo is offline I have the following voltages:
Q1: 1.65V - 21.8V
Q3: 1.65V - 23.5V
Q2: 1.65V - 23.5V
Q4: 1.65V - 23.5V
AVCC Buffalo: 3.3V - 3.3V
When connecting Buffalo:
Q1: 1.65V - 21.8V
Q3: 0.8V - 45V
Q2: 0.8V - 45V
Q4: 0.8V - 45V
AVCC Buffalo: 2.4V - 3.3V
Zener are removed.
Any advice please!
A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 1763 3rd April 2015 01:33 AM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 03:40 AM
FS: Elektor Audioo DAC-2000 w/Pass labs D1 clone I/V sachi Swap Meet 4 26th November 2010 04:57 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Copyright ©1999-2017 diyAudio
