| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#411 |
Owen,
Oh and why is this coming up now exactly? Let me clear. I am not the one who originally said that even a low impedance makes a difference. if you read through the original ES9008 thread and the output stage design guidelines on the ESS site you will see where Dustin mentions it. I also never claimed to have scientifically proven the degree to which 1 or 2 ohms makes a difference. I did say I would like to measure it at some point, and I firmly believe this result could vary depending on the rest of the circuit under test. One cct may measure very well with 2ohms and another not so well. So in fact all I have ever said is that I tend to agree with the chip designer and that I don't have the equipment to disprove him even if I cared to. I am also not the only designer who has said precisely the same thing. It does matter, but to what degree? Who is to say?I did say that for my part I did not like the single FET approach as much. That is a personal opinion. Its a simpler circuit, if I liked it as well I would have used it. I do believe the lower impedance approach *sounds better*. So based on my personal experience I went with what I liked best. There is nothing more to it than that. One person did measure the Legato (early version) and reported -118db THD. I can't confirm or deny it. I didn't do it. ![]() I have made no performance claims other than what I observed from simulation and what others have measured. I would be glad to work with you, I have nothing to hide. What I can say is that in the past measured results have actually very closely matched my simulated results. Today I will put the Legato 3 on the scope and measure the inputs at 0dbfs DAC output. I did this once when I first did the legato 1, but the cct has improved since then. If I remember correctly the result back then < 3mvpp peak to peak differential. In any case I certainly would not have gotten the impression there was no angst. But if you say there is none, I suppose I can trust that is the case. ![]() BTW I love to design things, but I am not an engineer (nor have I ever claimed such) with a full set engineers tools. I make the best use I can of what I have. I start with what makes sense based on what I know and learn, and then I work to make it sound as good as I can. Every experience brings a new depth of learning. That is why I do this. I have always supported your project, I don't get the same feeling in return. I think the problems may have arisen when I mentioned that I had tried the D1 approach and while I like it I was not completely satisfied. if that offended you I apologize. There was no such intent. Cheers! Russ
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 19th September 2011 at 07:03 PM. |
#412 | ||||||
Hi Russ,
It's coming up now because of your post yesterday: Buffalo III DAC Tube Output Stage Quote:
![]() I really do appreciate all the work you do, and I think you turn out some great products at fair prices. I just take issue when you overstep the boundary and turn from Technical Ross into Salesman Ross. One I appreciate, the other I do not. This is the sort of thing I'm talking about: A New Take on the Classic Pass Labs D1 with an ESS Dac If you want to support, then just say "Great Work!" and if you have meaningful technical input, then just say "Hey, you can improve the distortion performance by lowering the input impedance of your circuit". When you say things like: Quote:
Regards, Owen |
#413 |
Owen,
Fair enough I can see how you might see it that way, but I really had no intention of trying to sell anything on this thread at all. You and I both are not doing anything particularly new here. I have tried exactly what you are doing (yes high voltage, high gm devices and all) along with many other approaches. Like I said I think the approach sounds great, I personally was just not completely satisfied yet, and I thought the practical issues would be an impediment to many. I said what I said about the small amount of impedance making a difference based on personal listening experience and based on taking what Dustin said to me and on the forum to its logical conclusion. I don't mind in the least saying some of it is speculation, but most of it is also based on hard work and experience. For example we had a third party measure IVY-III (name omitted to protect the innocent) and found exactly that. Now I understand that is a completely different beast, that is why I offered the caveat that not all circuits may respond in the same way. I am not trying to sell anything here, but I think it perfectly natural to talk about ideas that influence designs. The only reason I even mentioned it was because this design was being used for Buf II and because I had a lot of interest in the topic itself for quite some time. I was looking forward to seeing how people received it. BTW I just measured the inputs of legato 3.1 at 1khz 0dbfs and got 2.2mvpp. Not as low as IVY-III but still pretty good. ![]() Cheers! Russ
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 19th September 2011 at 10:34 PM. |
#414 |
Hi Russ,
I appreciate you looking at it from my point of view. I know neither of us are creating earth shattering new ideas, and all of this has been done before, sometimes a depressingly long time ago. At this point it's about baby steps for me... getting the job done one small improvement at a time. That's an impressively low input impedance for the Legato, and no doubt keeps the ESS DAC in its happy zone. Thanks for taking the time to verify it. My offer to run the Legato (or anything else you might be curious about) through the AP still stands if you're interested. You know where to find me. Regards, Owen |
#415 |
Guys,
Don't take it so seriously. The legato and Owen D1 maybe from electronic point of view are similar, but from user point of view they are different beasts. Most of DIY user do things to have good gears, but mostly to do things and learn new things. Legato is a wonderful project, that you can make it sing in a couple of hours, even if you are a beginner. It's hard to screw up things there, and allow many people to access a great DAC and to fully enjoy. This is an incredible merit of the kit. Still there are things I did not understand (and I did not ask yet). You cannot say the same of Owen D1, and this is exactly why I did it. I had to start learning how to recognize SMD components, going on to learn how to solder them, learning about characteristics of tin, that in other applications are irrelevant. I took it as a challenge for my manual capabilities, and to learn new things. Some people had to sell the kit, as it was too difficult, others had to ask help as they could not even see the components. And still, I understand 10% of what Qusp had to go through to match the MOSFET. I think a proof of this is that most of us have both kits. The performances of both kits are so high, that I think the preferences of one over the other are fully personal, a bit like wine. It's interesting to see measurements, mostly if done with great equipment like the AP. For me is always a bit frustrating to do measurements, as nothing works as it should, but I Think nobody would judge the sound over a 2 dB difference in THD down at -160 dB. I wish I could hear that. I commented in favor of the D1, and this could be real, or only a psychologic effect, as I had my last toy done, but it could also be that the implementation is very different. My legato is powered with two salas regulators with a wimpy transformer, shared also with the buffalo. The D1 has four toroids, left and right supplies are separate and the Balanced to Unbalanced converter is done with "the wire" that I guess have better opamp than the legato2, as TP upgraded that part in the legato3. All this difference can matter! The point I wanted to make is that I do not see room for competition here, maybe for collaboration. I also don't think that the commercial interest matters here. As I pointed out the market point of this thing is so different, and you are both too busy, so I don't think any of you is fishing for more customers. Beside the fact that more D1 means more Buffalo, so you are helping each other anyway. As Nelson said:"This is the entertainment business, so I hope everybody is having good time". Best Regards, Davide |
#416 |
Can't wait to get my hands on one of those boards!!!
![]() I'm getting jealous of all of you completing the build... Just one question... Can we do dual mono BII with two boards? Do
PREAMPs : α10 with JC-80 clone | B1 Buffer | X-10 | AMPs: β24 | Aleph 5 | ChipAmp LM3886-4780 | Hiraga | ML-2 | Fetzilla DACs : TPA Buffalo II in Dual Mono + TP Legato 3.1 I/V | Tube-I-Zator I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | KEF Q55 |
#417 |
Sometimes a square peg fits a round hole just fine
you can indeed, but it requires a pretty serious commitment wrt casework and layout as the NTD1 is so large with the heatsink. if you can make a custom enclosure, or have one suitab;e for a largish class A power amp, or just one with a really chunky floor and walls you might do it that way. dual mono you will have to find a way to get rid of 100W of heat
#418 | |
This is a massive heat dissipation! And I'm actually starting to build a Aleph X... Can you imagine how much AC I will need in summer! ![]() Do
#419 |
hmm, a little, tbh i would be more likely to run the 2 dacs in parallel and drop the IV and gain resistors, or leave it the same if you have made your own amps and can make sure their inputs can handle it. the crosstalk is so minimal with well design balanced gear that dual mono is not really needed imo. can you tell the difference between
~-114 and -117 db THD+N? haha yeah well i have about 2.5kw in power amps i'm in the middle of building including an Aleph JX its 30c in the shade here many days without the 'audio-heating' |
#420 | |
Running the DACs in parallel is just a matter of stacking them on top of each others? I might just use one DAC for this and have another one left to play with! Ciao! Do
| A New Take on the Classic Pass Labs D1 with an ESS Dac | opc | Digital Line Level | 1044 | 23rd May 2012 08:44 AM |
| FS: Elektor Audioo DAC-2000 w/Pass labs D1 clone I/V | sachi | Swap Meet | 4 | 26th November 2010 04:57 PM |
| IRF610 I/V convertion from Pass Labs D1 dac - single ended | schiller | Digital Line Level | 5 | 15th October 2009 04:33 PM |
| Pass D1V3 DAC - build thread | spzzzzkt | Pass Labs | 222 | 28th August 2009 12:40 AM |
| Page generated in 0.17209 seconds (84.35% PHP - 15.65% MySQL) with 11 queries |
