BUILD THREAD - A New Take on the Classic Pass Labs D1 with an ESS Dac
Old 1st December 2012, 10:17 PM   #461
ed linssen is offline ed linssen  Netherlands
Default GB parts change to Buzzborb
Hi OPC,
Could you please try to read my PM (sent two weeks ago) and tell us what to expect? Both me and Buzzborb.
Thanks and sorry for (ab)using your time,
Ed
Old 2nd December 2012, 11:25 PM   #462
Originally Posted by ed linssen View Post
Hi OPC,
Ed
Buzz F orb of course, sorry!
Old 3rd December 2012, 12:04 AM   #463
opc is offline opc  Canada
opc's Avatar
Read and replied!
Unfortunately the boards shipped out long before you guys decided to swap so it will have to make the trip back across the ocean to buzzforb in the USA once it arrive in the EU.
Owen
Old 19th January 2013, 02:56 PM   #464
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Hey Owen - I was wondering if you ever built this enclosure? Based you your approach, I drafted a similar case. Dimensions will be 11in deep by 16in (ID) wide and 6in tall. Total width is between 20in and 24in, depending on if heatsink extensions are installed. I found some unique heatsink on eBay for this.
With the height, I partitioned it as two 3in levels. Heatsinks were $35 each, and raw 6061 aluminum came to $166. Wouldn't even tell you what it's costing me to have is milled, drilled, tapped and polished. I'll just say that I'll not be going 'all in' on a case like this until I build up a small shop with the gear I need to do it myself.
Anyway, as much as I've enjoyed the NTD1, it'll be worth it. Case should be assembled by the end of next week. I'll post pictures
Originally Posted by opc View Post
Hi Guys,
I drew up a quick model of what my plans are for the DAC, so everyone can get an idea of where I'm going with mine.
For reference, the bottom plate is 0.5" thick, the whole DAC is about 12.5"wide by 12.25" deep and 3" high
I'm going to use Aavid 65535 extrusions cut to 3" lengths for the sides.
The 1" by 1" bars will transfer heat from the bottom plate to the sinks, and the whole thing should run pretty cool.
The .zip attachment is the Google Sketchup file.
Owen
Old 21st January 2013, 02:16 PM   #465
adelias is offline adelias  Greece
I thought that I would post a few photos of my DAC in its current state. Although not completed by any means, I believe its close.
Old 21st January 2013, 04:03 PM   #466
opc's Avatar
Wow! I am green with envy!
That is by far the cleanest implementation of the NTD1 I've seen to date.
Wanna make me one?
Mine is still a tangled mess of wires in my media cabinet
How are the thermals? Does it run at a decent temp?
What is the deal with the output arrangement? I can't quite figure out from looking at it how you hooked it up.
Owen
Old 21st January 2013, 06:04 PM   #467
After running it for 8 hours the temps seemed acceptable.
The output has a relay that serves as a pass-thru for my surround processor when the DAC is turned off.
Old 22nd January 2013, 12:01 AM   #468
qusp is offline qusp  Australia
qusp's Avatar
looking good adelias, only one thing I can see, I see a familiar coax cable type that if it is what I think it is, its magnetic.
Old 22nd January 2013, 12:22 AM   #469
bigpandahk is offline bigpandahk  Hong Kong
I've search the thread but can't find the answer, could someone help?
Can the NTD1 output be connected as SE (unbalance)?
Old 27th January 2013, 08:24 PM   #470
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
I was planning to use a single transformer for the NTD1 power supply but make a secondary for each supply.
Please let me know if good enough. Also, I am planning for voltage drop for the regulators but want to make sure the safety margin is good enough. I don`t want the regs having to drop too much voltage since I don`t want them to overheat but don`t want them to sag either.
Dual Primary 115/230Vac - 250VA total
Quad Secondaries 41Vac (ea. 55VA) + dual secondary 9Vac (ea. 15VA)
Of course shielded encapsulated.
Anybody have part numbers (Digikey, Mouser, etc) for the BII/BIII headers to the NTD1 PCB?
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
BUILD THREAD - A New Take on the Classic Pass Labs D1 with an ESS DacHide this!Advertise here!
A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 1763 3rd April 2015 01:33 AM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 03:40 AM
FS: Elektor Audioo DAC-2000 w/Pass labs D1 clone I/V sachi Swap Meet 4 26th November 2010 04:57 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Copyright ©1999-2017 diyAudio
