Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th July 2003, 11:10 PM   #1
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Angry De-emphasis
Which jerk invented de-emphasis? I'd like to go back in time and smack some sense into him.
Thank you,
jwb
Old 15th July 2003, 11:14 PM   #2
SY's Avatar
Just curious: how many discs actually use it?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th July 2003, 11:24 PM   #3
jwb's Avatar
Nearly zero. That's why it is absurd that so many pins, registers, and datasheet pages are wasted on this subject.
"The CS3453243 includes a feature that can ruin the sound of any CD. Please make sure you write hundreds of lines of microcontroller assembly to ensure this feature is actually off."
Old 16th July 2003, 02:39 AM   #4
mb is offline mb
I wish it was nearly zero...
Some of the discs I have that have pre-emphasis:
- Glenn Gould, Goldberg Variations (Sony, 1981 version)
- Emma Kirkby collection (Hyperion)
- Several Sheffield Labs (Dave Grusin, Amanda McBroom)
I'm sure there are more, but these the Gould recording alone makes it indispensible.
I only paid attention when I started suspecting that a dac I had bought did not de-emph correctly. The designer did not implement, even though the chips were fully capable. Took me some *delicate* smt soldering to put in the connection required. Now I have a one-of-a-kind dac of this model that does de-emph correctly (automatically)!
Old 16th July 2003, 03:17 AM   #5
jwb's Avatar
It's just a nuisance, that's all. To properly handle de-emph in my new design, I need to bypass the sample rate converter and enable the de-emph on the digital filter when the receiver detects it. I also need to read the sample rate from the receiver to configure the filter, although if I assume the input sample rate of any de-emphasized stream is 44.1kHz, I should be OK.
Old 16th July 2003, 07:43 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
I have 700 CD's and 10 have deemphasis. One of them is Roger Waters, "The pros and cons of hitch hiking"
Deemphasis was developed in times where 14 bit resolution was common and 16-bit was just only a dream. I don't understand the fuzz for a such small enhancment. I can switch on and off the feature with my DAC and the difference is huge
BTW: Americans the cover of the american cover has the behind of the girl covered with a black rectangle not the original european relase.
When I see this I think of USA a the main producer of porn. This was only a reflexion....
/Per-Anders (my first name) or P-A as my friends call me
Old 16th July 2003, 08:03 AM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Do what? Why don't you just implement de-emphasis as it was meant to be done - in the analogue domain? All you need is two resistors and a capacitor per channel. The time constants are 50us and 15us, so the upper resistor needs to be 2.33r times the lower resistor, and CR for the lower resistor and capacitor needs to be 15us (assuming zero source resistance and infinite load resistance).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 16th July 2003, 08:18 AM   #8
peranders's Avatar
Why make it complicated, just use a modern DAC which does this rare filtering digitally.
Old 16th July 2003, 09:20 AM   #9
EC8010's Avatar
Default Complicated?
It sounded as though jwb was having to do a whole load of complicated digits, whereas the analogue solution is easy.
Old 16th July 2003, 04:06 PM   #10
jwb's Avatar
Ah, that's an excellent idea! So I could just use a FET switch and the active-low EMPH output of the AES receiver to activate the filter. Of course I'd need four for balanced, but I like it.
Thanks a bunch.
analog CD de-emphasis net-david Digital Source 7 8th January 2009 08:03 AM
What causes an emphasis on 'cha' and 'sss' vocalizations? Wseaton Multi-Way 29 25th August 2005 07:53 AM
de-emphasis...??? Lyra Digital Source 4 14th February 2004 11:59 AM
Upsampling DAC and De-Emphasis flag? pquadrat Digital Source 3 6th December 2002 02:01 PM
De-emphasis sylin Digital Source 5 6th May 2002 12:17 PM
Page generated in 0.11030 seconds (78.99% PHP - 21.01% MySQL) with 10 queries
