| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hello to everyone.
I want to update my Philips 304 with a pair of TDA 1541. I already found some threads here..but i could not find the aswer to all my questions..so i hope that someone will help me. After switching the TDA1541 in simultaneous mode..is better to think about a reclock..? Or to use the diagram here enclosed? I would like to use also the DEM reclock circuit proposed by ECdesign..is it possible to use it with the TDA 1541 in Simultaneous mode..? If yes ...How? THanks again. MAurizio. |
#2 |
I was who made the hand sketch on the left. In simultaneous mode it is important to reclock the LE (Latch Enable) signal, since it controls the conversion. The CLCF- is a pulse train, it can not be used for DEM. You can combine the I2S attenuator (it should work also for simultaneous signals) with my circuit. As for the DEM, I have no experience, but I think it is better to keep it below 1 MHz. Try a /4 or /8 divider from the master clock - or ask _ecdesigns_, he knows the TDA1541A in and out.
#3 |
Thanks for your reply..
I'm thinking to prepare one pcb for the two tda1541, and one to replace the SAA7030 with your circuit buiklt in.. I will try to ask to EC design if he can help me about the DEM Reclock. Thanks again. Maurizio. |
#4 |
HI Osi..
Did you get real benefits reclocking the LE? Did you compared the sound with or without LE reclock? Thanks. |
| TDA 1541 Philips Cd Pro2 | nafanja | Digital Source | 2 | 24th November 2008 05:39 PM |
| Ghetto Philips CD471, 1541 inside, mods ? | brianuk | Digital Source | 10 | 14th April 2004 06:19 PM |
| Phillips/Marants TDA 1541 CD 80 mods. | goldears | Digital Source | 21 | 18th January 2004 12:29 PM |
| Non os reclocking, I2S and DEM reclocking | Zodiac | Digital Source | 13 | 16th January 2004 11:24 PM |
| Page generated in 0.09388 seconds (73.77% PHP - 26.23% MySQL) with 11 queries |
