VC23, my new PGA2310 project
Old 7th July 2011, 01:45 PM   #61
hifimediy is offline hifimediy  China
yes, you can even use a DC 12V~15V for digital supply.
Old 17th July 2011, 02:22 PM   #62
Default VC43 up to 8 channel is coming
2x PGA4311 will be used. And with OP buffer each channel like we do on VC23.
Old 1st August 2011, 07:16 AM   #63
platenspeler is offline platenspeler  Netherlands
platenspeler's Avatar
Default Finished my pre-amp
I finished my little pre-amp based on the VC23 of Hifimediy yesterday. Some time ago I built a small/simple pre-amp with rotary switches and 2 opamps, but as one channel broke, I decided I wanted remote control as well.
So I took out the old board an replaced with the VC23 board. Two pictures attached (hope pictures are not too large).
As you see, I made a mod to one of the power connectors (the other one was too tight). The PCB fits in a standard eurocard case, however due to the placement of the power terminals you can't easily slide it into one of those boxes.
In the picture below the preamp is the power supply delivering 15-0-15 V dc(!). The two boxes on either side are gainclones/chipamps based on the LM3875
Initial listening confirms that this amp is an improvement over my previous pre amp. Not so much the sound quality, that was already very good, but ease of use is fantastic.
Some other remarks:
  • I think Hifimediy should include some sort of short manual. Of course lot's of material can be found on the forum, but it's no substitute. Also the website does not contain such documents for download.
  • There is no list of parts that are or should be in the box. So it is hard to say whether or not you received all components.
  • Only two connecting cables are included. Since it has one output and 4 inputs, this is not enough. Are the others missing, or should I buy the others myself :-)
  • Both of the Opamps were dropping out of their sockets as they were fitted too loose.
Above comments not meant to be too critical, but maybe they help to improve the product.
regards,
Maarten
Old 3rd August 2011, 08:07 PM   #64
IBM5150 is offline IBM5150
Default Looks Great!
Nice job Maarten, very well executed - looks professional. Amps look great as well.
I am trying to install my VC23 in an old PC power supply case. Will post pics when I get something together, but I am not such a craftsman. Will need an amp solution after the preamp is done.
Old 10th August 2011, 11:16 PM   #65
ecodoppler is offline ecodoppler  Italy
Default VC23 PREAMP
Hi
we wait the second improved version, a manual and maybe a good power supply.
Platenspeler, your listening impression?
regards
ecodoppler
Old 11th August 2011, 10:38 AM   #66
hi Maarten, very nice work. The ALU case is a good choice for diyer.
Old 15th August 2011, 03:37 PM   #67
Default AC or DC?
Maarten: How is it you are able to use 15-0-15 VDC?
I powered mine up and got a horribly loud 60Hz buzz and the amplifier wasn't even turned on. I used one leg of the 12.6-0-12.6 VAC for the digital circuit.
Agreed, some instructions should be included. Does the board need to be grounded?
Old 15th August 2011, 09:59 PM   #68
i just happened to have the 15-0-15 Vdc power supply. i figured that 12Vac would probably result in 17vdc after rectification, so 15Vdc would probably still be Ok. On the picture you can see the wiring (red/red and green/blue) are same.
i did not ground the amp itself, but looking at my documentation of the ps the black (0vdc) wire is probably connected to safety earth somewhere inside the ps (have to check)
Maarten
Old 15th August 2011, 11:47 PM   #69
Default VC23 build photos
Here are some pics, still trying to figure out the buzz... Switched the digital input to 15 VDC and still had the buzz, then a 2nd tone started and was getting louder very quickly. Does the polarity matter on the digital input?
Old 16th August 2011, 12:07 PM   #70
Hi, IBM5150, when your system use not only VC23 boards, I suggest test each board separately, that will more easy to find what's the problem.
And I also suggest use a standalone power supply for the digital part of VC23, and VC23 already has a (analog and digital)ground junction itself on board.
VC23, my new PGA2310 projectHide this!Advertise here!
Powering a PGA2310 Ductapemaster Power Supplies 5 13th May 2008 03:07 PM
No microcontroller for PGA2310? louischia Chip Amps 12 4th March 2007 06:12 PM
pga2310 preamplifier mos Digital Source 2 6th September 2006 02:04 AM
PGA2310 v PGA4311 daArry Digital Source 1 12th April 2005 07:52 AM
PGA2310 Question blu_line Solid State 10 30th January 2002 09:16 AM
