VC23, my new PGA2310 project
Old 27th October 2010, 06:44 PM   #31
alkasar is offline alkasar  France
Originally Posted by hifimediy View Post
And modify the gain range: -87dB~40dB now.
i prefer this range
what is ZCEN ?
also, will the brightness of the display be adjustable ?
an idea of the price?
Old 27th October 2010, 06:48 PM   #32
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Zero crossing detection. Read the dataheet.
Old 27th October 2010, 07:24 PM   #33
thx (you seem to be good at acronyms !)
Old 28th October 2010, 10:50 AM   #34
hifimediy is offline hifimediy  China
Originally Posted by alkasar View Post
i prefer this range
what is ZCEN ?
Not now, but I can try add the brightness adj. function later.
And what price do you think is ok? I'd like to discuss that too, making price acceptable by most diyer is another important thing.
Old 28th October 2010, 11:25 AM   #35
pipsk is offline pipsk  Slovakia
do you plan something with tone controls?
Old 28th October 2010, 02:49 PM   #36
I'm processing another project with tone control: http://www.diyaudio.com/forums/class...amplifier.html
Old 28th October 2010, 04:05 PM   #37
Hehe you always refer me to next project. I need to build 2 channel amp (preamp + amp maybe) that has enough power (min 160 W 4Ohm) and tone controls. (just in case) You can directly refer me to something if you have it, or I'll just find something suitable for T3 . I'd rather have the tone controls than not have them and need them, somthing with bypass function would rock... but I didn't find something that's good and bang for the buck as your products are. Anyway thank you for your time and great work!
Old 29th October 2010, 05:15 AM   #38
fb is offline fb  Australia
Well, I'm very interested in this..... I'd been going to design one myself anyway, already have the PGA chips too.
I need 6 channel balanced I/O!
Old 1st November 2010, 03:43 PM   #39
Just finished brightness adjustment function. There is 4 levels of brightness now.
Old 12th November 2010, 05:24 PM   #40
Hello Hifimediy,
Let me summarize the features :
- volume control using pga2310 chip (-87dB to +40dB)
- 4-channels input selection
- 3*7seg display and rotary encoder on a separate board,
- rotary encoder used for volume control, input selector (short press), on-off (long press)
- remote control http://www.diyaudio.com/forums/attac...ier-remote.jpg
- learnable remote
- extendable for multi-channel by adding one or more daughter boards
- display brigtness control (4 levels)
- ability to control on/off of external board
- on-board switch controls
sw1: on-auto save configuration when power off; off-default configuration
sw2: on-display always on; off-display blank after about 5sec no action
sw3: on-remote learning mode; off-normal mode
sw4: on-ZCEN enable; off-ZCEN disable.
- PCB size: 128*100mm
- PSU on board. Only needs transformer. +/-12VAC to +/-16VAC transfomer will be ok i presume.
I hope I catched them all
Now some more questions :
- on/off control of external components.
I would like to use this to trigger two relays : one to power a dac, the other to power the amp. Will the signal have enough current to trigger two relays ? what will the control be : +5V ? +12V ? other ?
- the board seems to have two opamps. What are these for ? are they on the signal path ?
thanks
VC23, my new PGA2310 projectHide this!Advertise here!
Powering a PGA2310 Ductapemaster Power Supplies 5 13th May 2008 04:07 PM
No microcontroller for PGA2310? louischia Chip Amps 12 4th March 2007 07:12 PM
pga2310 preamplifier mos Digital Source 2 6th September 2006 03:04 AM
PGA2310 v PGA4311 daArry Digital Source 1 12th April 2005 08:52 AM
PGA2310 Question blu_line Solid State 10 30th January 2002 10:16 AM
