VC23, my new PGA2310 project - Page 14 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd September 2012, 02:56 AM   #131
Default Working now!
When I set DIP 3 to ON, shut down and restarted it wouldn't come back on. Turns out my power switch was bad. Fixed that and it is all good now, programming was a breeze. Good idea on the relay, I will do that.
See attached for latest box configuration.
Thanks!!!
Eric
Old 8th October 2012, 10:35 AM   #132
I want to buy this Préamplification - AUDIOPHONICS PGA-8CH - Contrôleur de volume 8 entrées PGA4311 --> VC43
How much VA need a VC43 board? I want to use a toroidal transf 2x09V + 1x06V.... how much Amp is need for each lines? IS good 2x09V or is best 2x06v?
Thanks.
Old 8th October 2012, 01:44 PM   #133
Thanks.
hi, PGA4311 is +/-5V supply for analog, so 2x6V is better to get lower power loss. A transformer about 9VA is ok for VC43.
Old 8th October 2012, 02:50 PM   #134
Thanks but 9VA is total for 2 lines +/-6v (line 1) and +6v(line 2) for example:
2x6V AC 0,5A
1x6V AC 0,5A
2x(6x0,5)+1x(6x0,5)= 9VA?
Audiophonics tell me that a dedicated custom toroidal for this board is :
30VA +/- 6 V + 6V (30 VA 4 windings)
is exagerate?
Old 22nd October 2012, 03:37 PM   #135
Hi hifimediy, vc23 is sounding great, really silent (no floor noise or humm) on my speakers until maximum gain ... but just a question.. when I start to go high in level let's say from -5 dB up to max. I hear some clicks every time I increase or decrease level. This happen ONLY if I do that without input source connected. If I short input to GND or have a source signal on that channel, this doesn't happen.. could be a problem depending on too high input impedance (30kohm in my board).. ?
Old 22nd October 2012, 05:10 PM   #136
Default TV Remote Interference with VC23
Was able to program the remote to control the VC23 with channel and volume with the cable box remote, but still problems. Whenever a button is pressed on the cable box remote when in CABLE mode, either channel up/down, List, back, play, etc it has a bad effect on the VC23 - usually raising volume, even though the "audio" function is not enabled. Here is the remote: Atlas OCAP 1056B03:
Atlas OCAP DVR Setup Television Control (1056-BC03)
Is there a fix or work-around for this? I may have to move the VC23 and amp to a different room as it can't be on at the same time the TV is on, but I really wanted to use the VC23 and amp for better TV sound.....
Thanks in advance.
Eric
Old 22nd October 2012, 06:18 PM   #137
jcga is offline jcga  France
Look's typical of small DC present in the signal flow, if it's the case then adding a cap in between will help
JC
Old 25th October 2012, 03:48 PM   #138
JC
True.. the click was an offset problem.. I adjusted the offset trimmer to have 0.0 mV on pin 6 of the op amp and the pops are gone.. thank You.. Now it works really great
Old 21st July 2013, 06:51 AM   #139
Can anyone who have bought VC43 from Audiophonics share his experience?
In particular I've two questions:
- when the module is switched on or off is there any noise (bump)?
- I've read in some french forum that VC23 was sensitive to light bulbs in the room and remote controls used in other rooms; has VC43 the same flaw?
Fabrizio
Old 5th November 2013, 06:30 PM   #140
ok.. I understand.. but another question... is it possible to modify MSP430F149 internal parameters in order just to modify GAIN LIMITS (-70dB to +3dB) of VC23 ? I mean... connect the MSP430 UART R/T of the hader on board via UART-USB adaptor to PC ? Because I'm not so expert on MCU programming.. which software should I use to do that ? Is it a difficult operation to do ?
Thank You..
Powering a PGA2310 Ductapemaster Power Supplies 5 13th May 2008 03:07 PM
No microcontroller for PGA2310? louischia Chip Amps 12 4th March 2007 06:12 PM
pga2310 preamplifier mos Digital Source 2 6th September 2006 02:04 AM
PGA2310 v PGA4311 daArry Digital Source 1 12th April 2005 07:52 AM
PGA2310 Question blu_line Solid State 10 30th January 2002 09:16 AM
Copyright ©1999-2017 diyAudio
