VC23, my new PGA2310 project - Page 13 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th September 2012, 11:15 AM   #121
Originally Posted by luckyaua View Post
...ok
if i use 2 boards for 8ch balanced in/out i must use 2 display and 2 remote controller or i can use one only remote and/or one display.
Excuse me for questions...but i wonna be sure that this board is useful for me!
Yes, there will be 2 display, that's problem for 8 channel xlr use, because the boards can not 'talk' to each other by now.
Old 20th September 2012, 01:17 PM   #122
so... instead if i use for 5.1....3 VC23 --> Préamplification - AUDIOPHONICS PGAVOL - Contrôleur de volume 4 entrées PGA2310
for 6in/6out with possible of selectable 4 different 5.1 source...so how can i bridge the input 1..4 of each boards and use only one display/knob board and remote for drive all 3 boards?
Old 20th September 2012, 02:40 PM   #123
Hi luckyaua
Again we don't support multi-board using. VC23 now only support up to 4 channels(with a 2 channel external module) max. Thanks.
Old 20th September 2012, 02:41 PM   #124
thanks for all....
Old 20th September 2012, 07:46 PM   #125
Originally Posted by hifimediy View Post
Hi, I suggest keep the OP because the input impedance of PGA2310 is not big, so a buffer is always needed. If you can, keep the R7=R11 and R9=R14, then the OPs will become a buffer with gain=1.
Hi, I also have a VC23 bought from audiophonics.. it works fine but I'd like to know if it's possible to set the maximum gain = 0db.. I mean, to keep on using the input opamp as a gain stage, and use the PGA just as attenuator... this function was described on the site, by setting the dip-switch.. but it seems not work ! Please help thanx
Old 21st September 2012, 01:05 PM   #126
Hi, sorry but VC23 doesn't support 0dB maximum function.
The configuration of switches:
1: Auto save settings
2: Display on/auto off
3: Remote learning mode
4: Control port output level
Old 21st September 2012, 05:25 PM   #127
ok thank You.. could You explain what mean for 'Control port output level' ? if on or off what happens ? Changes in gain or something ?
Old 21st September 2012, 08:20 PM   #128
Re: Post #55 on Page 6 of this thread: 1) Can you tell me how to use the VC23 to turn on the T1 amp? 2) How do I use the Remote Learning Mode SW3 and the 111/222/333 codes? If I use the remote on the TV it changes the volume in +5dB increments, even the volume down, so pretty soon the amp was at 100%. Thank you in advance.
Old 22nd September 2012, 01:46 AM   #129
Hi, "Control port" is CN9 on VC23. And here is the sw4's purpose:
on-amplifier control port active high level(3.3V TTL logic output);
off-amplifier control port active low(3.3V logic output)
Hi, I think you can use a relay to power on/off the AC power supply (220V/110V). When we put sw3 on, and VC23 will enter learning mode when power on, use a remote and press keys to learn the code. Operating sequence: 000-ON/OFF, 111-MUTE, 222-Volume down, 333-Volume UP, 444-Channel down, 555-Channel up, 666-learning end, then repeat for another cycle if needed.
Old 22nd September 2012, 01:49 AM   #130
...... If I use the remote on the TV it changes the volume in +5dB increments, even the volume down, so pretty soon the amp was at 100%. ......
The volume will auto increase when you long press the remote. May be that's why you get 5dB step?
Powering a PGA2310 Ductapemaster Power Supplies 5 13th May 2008 04:07 PM
No microcontroller for PGA2310? louischia Chip Amps 12 4th March 2007 07:12 PM
pga2310 preamplifier mos Digital Source 2 6th September 2006 03:04 AM
PGA2310 v PGA4311 daArry Digital Source 1 12th April 2005 08:52 AM
PGA2310 Question blu_line Solid State 10 30th January 2002 10:16 AM
Copyright ©1999-2017 diyAudio
