Go Back   Home > Forums > Source & Line > Digital Line Level
Old 27th January 2012, 11:18 PM   #101
zman01 is offline zman01  Bangladesh
Default Newbie with VC23 preamp
Hi all,
A newbie here .
I have gone through the thread and see that there are 2 power inputs 12-0-12 and 6/9VAC on the VC23 preamp board.
I have a 12VAC power brick - can I use that to connect both points? Or do I need another power source? (Got 4-6V power adapter also)
-Zia
Old 28th January 2012, 02:23 AM   #102
Hi Zman - welcome! You sound like you are where I was at post #58. I used 12.6-0-12.6 and 12VDC 0.3 amp wall wart inside my case. My preamp is still working great although I no longer have the MiniDSP in it and put the VC23 in a new box.
Eric
Old 28th January 2012, 02:48 AM   #103
Eric,
Thanks for the reply - that means you are using 2 power supply units right?
-Zia
Old 28th January 2012, 03:56 AM   #104
Yes I considered tapping off one leg of the other transformer, but I didn't want to risk any noise or loss of performance, maybe it would be OK, not sure. See attached.
Old 29th January 2012, 07:59 AM   #105
The preamp was put together yesterday and is working fine! Thanks Eric on and others who shared details of their projects on this thread.
I have noticed one thing - if the amp (Hifimediy T4) is on before the preamp, there's a nasty pop out of the speakers when I turn the amp on. Is that normal?
Old 29th January 2012, 02:46 PM   #106
Glad you got it working. Yes that pop is normal. The usual order for powering components is preamp, source, then turn the amp on last. When shutting it down, turn the amp off first, then the other components - that should fix it.
Did you use a separate AC or DC power source or tap off the AC transformer?
Eric
Old 3rd February 2012, 01:42 PM   #107
Hello all!
Ahead of it all, please excuse my stupid question! I just received the vc23 from audiophonics together with a transformer with 2x12v and 1x9v secondaries. The two wires from the 1x9v winding go into the 9 v post, but I end up with 2x2 lines from 12v secondaries for the 12v post on the pcb. Can i just connect any of the two together as "0" and the others as the two 12 v lines (as in: blue - yellow+blue - yellow, where blue/blue and yellow/yellow are the 12 v secondaries?)
Thanks in advance!
Timo
Old 5th February 2012, 05:45 PM   #108
Never mind. Resolved.
Old 12th March 2012, 05:52 PM   #109
platenspeler's Avatar
Are there differences between the board sold by Audiophonics.fr and the one available on hifimediy.com? The audiophonics website says that dipswitch 4 controls whether the preamp amplifies or not (0 dB). But the hifimediy site says that switch 4 controls a "vendor option" and switching between on/off does not seem to make any difference in max volume setting.
I ask, because I have two VC23 boards at home and both start to be quite noisy (humm) above the 00 (dB) point, and I'm looking for ways to keep the noise down.
My simple PGA2311 board with only 6-0-6 Vac power and not so expensive components is dead quiet even at high gain settings compared to this deluxe board with all its possibilities.
Maarten
Ps. I just noticed that hifimediy does not sell/stock this board anymore...
Old 14th March 2012, 06:55 AM   #110
Hi, VC23 use a OP buffer at the input to get higher input impedance, this might lead to some hmm noise when dB level. Use a 47k resistor after input caps to ground to solve this.
Powering a PGA2310 Ductapemaster Power Supplies 5 13th May 2008 03:07 PM
No microcontroller for PGA2310? louischia Chip Amps 12 4th March 2007 06:12 PM
pga2310 preamplifier mos Digital Source 2 6th September 2006 02:04 AM
PGA2310 v PGA4311 daArry Digital Source 1 12th April 2005 07:52 AM
PGA2310 Question blu_line Solid State 10 30th January 2002 09:16 AM
Page generated in 0.10207 seconds (79.40% PHP - 20.60% MySQL) with 11 queries
