Soundcard clipping when volume control set to full
Old 11th October 2010, 05:24 PM   #21
billybudapest is offline billybudapest  United States
Originally Posted by AudioFreak View Post
Have you actually looked at the output waveform on a 'scope in Balanced (TRS) and Unbalanced (TS) output modes? What is it that you are driving from the output of the soundcard?
I use a software spectrum analyzer and scope from the inputs on the same device, I always ensure that the input never clips (with the exception of a direct loop-back TRS out to XLR in which I acknowledged does clip because of the gain mismatch). I have pads for when dealing with the unbalanced inputs, and I've never had to use them because the output in unbalanced mode doesn't get close to clipping the input.
To ensure that the balanced output does not clip, I ran the TRS output through a 10/4 interfacing box and then sent the unbalanced output back to the input for verification. No clipping present, so the balanced out is just a high level out but it does not clip.
When using unbalanced, I do a loopback. I have various pads so again the input being too high is never an issue. It clips before the input.
Old 11th October 2010, 05:27 PM   #22
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
When you connect T-S to the output jack, are you using a T-S male plug?
If so, try using a T-R-S plug, leaving R open.
If the R and S are shorted by a T-S plug, it could be causing the output amplifier to clip. Depending on the design, the board may derive the T signal by inverting the R signal.
Frank
Old 11th October 2010, 05:37 PM   #23
Yes I have been using a male T-S plug.
Frank, as was established earlier using only one of the outputs with ground corrects the issue. As expected, I can use either the tip or the ring as the hot for the unbalanced and it doesn't clip. So when using a T-S plug the jack shorts the Ring and Sleeve and then distorts very badly. That seems pretty bad, that it would function in that way. So whats actually clipping? And why? The final op-amp?
Old 11th October 2010, 05:43 PM   #24
The final Opamp. It probably has something like a 47 ohm resistor in series with the R output. The same for the T output.
When connected to S, this causes the R output to operate into a 47 ohm load .... too low for the chip. Leave the R open or connect it to S using a resistor which matches the impedance that the T sees.
I've seen this on other pieces of equipment. It puzzled me too until I figured out what was happening.
Frank
Old 11th October 2010, 05:47 PM   #25
Let me see if I can figure out the parts, I'll open it up and see whats actually there. Any difference in performance by lifting the ring and not using it shorted ( i mean if I corrected the issue)?
Old 11th October 2010, 05:51 PM   #26
That would be my choice. The output Opamps won't have to work so hard.
The distortion will be lower if you don't load the unused R.
Please let us know what you find.
Glad to give you my two-cents worth.
Frank
Old 11th October 2010, 06:43 PM   #27
Alright here are pictures of the output stage, perhaps they can say more than I can.
Perhaps you can also explain what the second row of dual channel opamps are doing. I thought only one would be necessary.
Old 11th October 2010, 08:17 PM   #28
I'm presently listening to it with manually jumping to the posts (so it doesn't bridge the ring and sleeve) will full digital volume and it sounds pretty good, less distortion in the mids and the dynamics seem a lot stronger than before. Would still love to know exactly whats happening though, and certainly why they would design it this way :/
Old 11th October 2010, 09:15 PM   #29
wakibaki is offline wakibaki  United Kingdom
Banned
OK, it seems you have already got to the bottom of the issue as regards how the volume control is implemented. Thinking in terms of 16-bit signed data for example (16-bit .WAVs are signed) the maximum excursions are -32768 and 32767. 0.5dB (the gain/attn step offered by the DAC) is a factor of 1.0592537251772888788092803732781. 32768 reduced by 0.5dB is 30935 (rounded). To reduce the output by 0.5dB the input sample would be multiplied by 30935 and divided by 32768. The division is trivial as it simply consists of discarding the rightmost 15 bits. Greater reductions in volume simply require a smaller multiplier.
Since the wheel-operated volume control can be overridden in software, it is obviously being read (it could be an encoder or a pot being read by an A/D) and the control effected by commanding the DAC. Personally, I would never design a DAC that worked like that precisely because of the degradation of S/N and quantization noise, which means that a user requiring the best performance from the DAC should never use the volume control, or rather should always have the volume set to max. It's not uncommon though in 'consumer' applications to disregard considerations of absolute quality in favour of 'convenience'.
As regards the output opamps the datasheet recommends an output filter using at least one opamp. This filter has a single-ended output. To convert this to balanced a couple more opamps would typically be employed:
This means we have 3 opamps per channel. The designers probably used the remaining one for a final adjustment of gain preceeding the balanced line driver.
w
Last edited by wakibaki; 11th October 2010 at 09:25 PM. Reason: To correct arithmetic
Old 11th October 2010, 09:32 PM   #30
Originally Posted by wakibaki View Post
OK, it seems you have already got to the bottom of the issue as regards how the volume control is implemented. Thinking in terms of 16-bit signed data for example (16-bit .WAVs are signed) the maximum excursions are -32768 and 32767. 0.5dB (the gain/attn step offered by the DAC) is a factor of 1.0592537251772888788092803732781. 32768 reduced by 0.5dB is 34710 (rounded). To reduce the output by 0.5dB the input sample would be multiplied by 34710 and divided by 32768. The division is trivial as it simply consists of discarding the rightmost 15 bits. Greater reductions in volume simply require a smaller multiplier.
Yeah that was what I was fearing, totally stupid process. The reason they did it that way, obviously, was that it was far easier to encode a single pot once and use that value for all of the output channels (there are 8 analog outs) than to have a way to control them all afterwards. A single pot for digital versus 8 analog TRS pots, or whatever other scheme.
So they take the differential output from the dac, convert it to single ended with one half of one of those dual channel opamps, and then convert it back to differential with another opamp? Isn't that a sort of stupid way to do it?
w
I see, so since I'm not concerned with balanced output perhaps I can bypass the final balanced line driver portion and jump directly to the output pin of that first opamp. Does that make sense?
The opamp datasheet is http://semicon.njr.co.jp/njr/hp/file...?_mediaId=5679
for reference.
Pin 1 on it, the top left most pin in the picture, is the output for the first opamp. I am guessing that this would be the point to attach to right?
Thanks again for all of the assistance guys, glad we have figured out a lot of it
Soundcard clipping when volume control set to fullHide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Serious clipping from motherboard soundcard chris661 PC Based 3 21st September 2009 02:12 PM
fisher 800c clipping at ultra low volume slhoward Tubes / Valves 12 15th May 2007 03:28 PM
Clipping? why not build amp with twice rms needed and only use half volume? John Biles Everything Else 22 29th September 2005 06:12 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
