How do I connect a current output DAC to I/V stage single ended
Old 22nd September 2010, 08:58 PM   #1
Thermosphere is offline Thermosphere
Default How do I connect a current output DAC to I/V stage single ended
I have an PCM1798 based DAC which has a passive I/V output stage and I am not very liked it. I want to try the new Zen JFET-based I/V stage and I have a (possibly very easy and dumb) question.
As you know the PCM1798 has differantial current outputs for each channel: IOUT(R/L)+ and IOUT(R/L)- . The Zen I/V has only one input. How can I connect these together to provide an unbalanced output?
I think I must connect the IOUT+ to Zen input and IOUT- to GND. Because I'm not very experienced these kind of circuits, I wanted to sure about this.
Thanks.
Old 22nd September 2010, 09:44 PM   #2
SemperFi is offline SemperFi  Wake Island
I did it like this, passive conversion. The DAC don't like large voltage swings, and the 50ohm resistors are a good match. The transformer is a Lundahl. Sounds pretty damn good
The output level is lower than redbook standard, but thats a good thing because you can crank the preamp volume, which means less wiper in the path.
Last edited by SemperFi; 22nd September 2010 at 09:46 PM. Reason: forgot the schematic:)
Old 22nd September 2010, 09:47 PM   #3
Like this that is:
Old 22nd September 2010, 09:49 PM   #4
Hmm, something is playing with me, cant seem to get the schem up. Perhaps I saved it in the wrong format....
Trying a jpeg.
Old 22nd September 2010, 11:40 PM   #5
jcx is online now jcx  United States
or use 2 Zen, diff to single ended with xfmr: ( from http://www.diyaudio.com/forums/digit...ml#post2306210 )
Old 23rd September 2010, 01:27 PM   #6
Sandor is offline Sandor  Italy
The should be almost no voltage between the drains of J1 and J3. Maybe the output capacitors may be omitted.
Old 23rd September 2010, 06:30 PM   #7
DougL is offline DougL  United States
True, but there is 30V between the drain of J1 and J2. While there are ways around it, juts removing the caps will not work.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 23rd September 2010, 07:12 PM   #8
And why do u want all that in the signal path when one resistor per phase is aplenty?
Old 25th September 2010, 06:03 AM   #9
qusp is offline qusp  Australia
qusp's Avatar
because 1 resistor is IMO and many other opinion, NOT PLENTY. you do not gain the best performance from the dac this way. current out dacs often prefer to operate into very low impedance and preferably with their outputs returned to a virtual ground biased to AVCC/2
Old 25th September 2010, 06:44 AM   #10
Irakli is offline Irakli  United States
Irakli's Avatar
I agree about low impedance, but what is gained by biasing virtual ground to AVCC/2 ?
My System
How do I connect a current output DAC to I/V stage single endedHide this!Advertise here!
URL collection of Totem Pole and CSPP (Single Ended related) Solid State Output Stage tiefbassuebertr Solid State 7 10th May 2012 06:02 PM
What is the tradeoff to run a DAC single ended? DougL Digital Line Level 13 11th October 2010 07:51 PM
How does the current source work in a single-ended amp ? tessier Pass Labs 1 4th September 2010 09:39 AM
WTB: Single Ended Output Transformers Zedguy Swap Meet 2 2nd August 2009 03:05 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 10:01 AM
Copyright ©1999-2017 diyAudio
