| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi, I am building this sp/dif buffer as suggested on the Lampizator site the schematic is on the page
CD Transport Digi-Lampizator It is a simple question :do I have the flat side of the "D" facing the signal wire ????? I take it the sp/dif signal enters the transistor on the centre pin.....It is not that I am too lazy to experiment , I am just worried wrong orientation would blow the signal generator chip or something nasty and the Quad 99 I am using is made of very very flimsy parts , I think it would be hard to repair..Thanks Alan... ps if I am worried about blowing chips can you protect them by using a diode in series along the signal wire?? |
#2 |
#3 |
hello,
this is the pin configuration of the bf245b, signal enters in G pin, which is at bottom looking at D |
#4 |
are these optimised for the sa7220, or can i use this on any chip?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert |
#5 |
Tfan69....does the power come in on the "s" or "d" pin then??????.....sorry for being so thick...
Luke .....I have no idea I was just going to connect it and see what happens....I do not even know what spdif generating chip I have ...all I know is is that a stock quad 99 is a very very poor affair indeed and needs all the help it can get |
#6 |
just look at the scheme and the pin image, power enters from d
#7 |
Hi, Tfan...I have built the buffer and am running it off a 9volt battery for a minute...its built as a external unit and plugs into the rear digital output socket on the player....and outputs to an external dac.... SO ....all rca grounds /battery ground and resistor grounds share the same rail........Before I plugged into the player , I put a multimeter on the output hot pin and found it is outputing 0.3volts DC before any sp/dif signal is applied....I was suprised to see the DC as I thought the 10 uf capacitor was supposed to block it....I have double checked everything and cannot see how I have varied from the diagram....so is this an acceptable amount of dc to be going to the dac or have I indeed messed up??? I have not plugged the unit in as I am worried about the dc....is my grounding right?
#8 |
hello.
you can connect a res (typ.100k or so) from output cap to ground.......so that (big) cap can be charged. are you shure that output cap reads 10uf ? or is it 10 nf (red schematic with the tube)? greetings |
#9 |
its definately a 10uf non polar just a cheap brand...i have left the thing powered and now when I read the pin i see....0.02volts dc....could this be evidence of the so called "burn in" of a electrolytic???? is 0.02v safe for the dac? I will raid my parts bin attach a resistor like you said .....see what happens
#10 |
it worked......o.oovolts...so I tried putting a 75ohm ...and the same result.....listening to it now.....can't say I am hearing any improvement in sound quality or details etc...maybe 9v is not enough...will have to mess around with the resistors as well
| Chip amp Speaker Protection Ideas | sksengupta | Chip Amps | 16 | 30th July 2010 11:38 AM |
| Parallel or Transistor assisted chip amp ? | ashok | Chip Amps | 39 | 15th September 2008 12:41 AM |
| LM3876 chip VS transistor 2sc2922 amp | space2000 | Solid State | 1 | 18th May 2008 02:19 PM |
| Chip amps and clipping/protection behavior | danielwritesbac | Chip Amps | 4 | 28th March 2008 04:58 AM |
| Chip Amps with no DC PROTECTION fine? | commstech | Chip Amps | 9 | 27th November 2007 02:24 PM |
| Page generated in 0.10249 seconds (78.08% PHP - 21.92% MySQL) with 11 queries |
