| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I have a DAC based on the PCM1794.
I have a passive analog section using a transformer. I was looking at the Zen I/V and wondering if I could use a single output and either: A. Ground the unused input. B. Place a small resistor to ground. C. Place an "active load" on the pin and not use the output. This was just a thought, it would avoid a balanced to Single Ended conversion, and allow a more standard volume control. The question is what do I give up for this? Thanks in advance. Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
#2 |
You give up to 6dB of signal/noise ratio...
#3 |
How are you doing a passive output stage? Doesn't the PCM1794 need an I/V stage at the output?
I could see maybe a transformer after that.
Take the Speaker Voltage Test! |
#4 | |
#5 | |
Doug
#6 |
transformers do diff to single ended
modern monolithic DACs use balanced output to reject large high frequency digital noise current in their substrate - its impossible to get decent S/N without differential output balanced circuitry also gives even harmonic cancellation the PCM1794 has large output DC current bias - your I/V has to balance this current with low Vos from gnd - otherwise you get nonlinearity as you start to have signal current shunted by internal protection diodes the Zen I/V may not have low enough input Vos for the PCM1794, doesn't have DC current balancing so the circuit needs some modifications to be compatible with this chip where ever you put it, your transformer must not have any net DC current in the windings - blocking C absolutely mandatory any or all of these ideas will perform measurably worse in distortion than the datasheet 5534 I/V - and much better op amp I/V is possible Last edited by jcx; 15th September 2010 at 04:23 PM. |
#7 | ||||||||
Zin was quoted as 15 ohms, and the common source input should be self biasing, especially since the outputs are not DC coupled. It certainly might benifit from 2 pairs of FET in parallel. Quote:
#8 |
The Zen I/V does sim ridiculously well, IMD as low as -100dB – but who knows how good the jfet models are or how well any particular current out DAC performs with nonzero input impedance and offset
jfet parameter match dependance could be explored - I really expect the complete 2nd harmonic cancellation seen in sim with idendical models is impractical with real world device variation There is offset of -124 mV at the I/V input with the nominal models and Nelson suggests a low Ohm pot V offset adjustment for mere mortals who don’t have hundreds of the fets to select the Idss matched pairs to get the 1 mV Vos he claims in his article, balanced I/V requires good matching of 4 fets I show a sim with AC coupled xfmr (it could give selectable balanced or single ended output) to the degree that the caps match there is some psrr but filtered/regulated power is still a good idea Cap physical size may be a challenge if you insist on film caps and low frequency response Xfmr ratio, frequency response and Cload modification of the response are all details that need to be addressed the current sources aproximate the PCM1794 +,- Iout, I show bias current cancellation R but not Vos adj Last edited by jcx; 17th September 2010 at 03:39 PM. |
#9 | |
Actually, you only give up about 3dB in SNR.
Ken |
#10 |
jcx,
Thanks for the simulation. Very interesting. Doug
| IRF610 I/V convertion from Pass Labs D1 dac - single ended | schiller | Digital Line Level | 5 | 15th October 2009 04:33 PM |
| Single Ended, Single driver: In-room distortion measurements | Gerrit Boers | Full Range | 4 | 27th November 2007 08:12 AM |
| Run opamp on single supply | Ryssen | Parts | 1 | 15th March 2004 12:28 AM |
| Anyone play with the Zen Single-Stage Single-Ended Class A? | Rino odorico | Pass Labs | 13 | 29th August 2002 09:01 AM |
| Page generated in 0.10823 seconds (82.24% PHP - 17.76% MySQL) with 11 queries |
