Go Back   Home > Forums > Source & Line > Digital Line Level
Old 14th September 2010, 04:10 AM   #1
Default Filtering digital noise on pin 1 of my DAC (XLR balanced)
Hello, I posted this question on AA but no answer so far: I discovered that I have digital noise running on the pin 1 wire inside my DAC. I have two questions (see attached picture):
A. Which configuration (1), (2), or (3) do you suggest to filter the digital noise on pin 1? Caps C are 0.01 µF as reccomended.
B. Any suggestion for the tech specs of the ferrite beads to use?
Roberto
Old 14th September 2010, 05:13 AM   #2
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
why not remove the ground wire altogether? its only there for the shield and really I dont see that its needed. I sure dont use it, CMRR is good enough and it reduces the capacitance too. why filter it when you can remove the source of the noise altogether?
Old 14th September 2010, 06:07 AM   #3
Thanks for the reply. I can use Rane notes' suggestion to connect pin 1 to chassis ground, or to avoid to connect pin 1 as you suggested. I tried both but I loose resolution in micro- and macro-dynamics. I tried configuration (3) as suggested by Rane, it is an improvement. So I'm wondering what it is the best configuration. My question is mainly related to the ferrite charateristics, since I can experiment the three configurations.
-Roberto
Old 14th September 2010, 02:46 PM   #4
Speedskater's Avatar
It's not "micro- and macro-dynamics" that you hear! It's noise from the mis-wired pin #1. Pin #1 is not part of the signal, it should be connected directly to chassis.
Kevin
Old 14th September 2010, 03:22 PM   #5
qusp's Avatar
yes, either dont use it at all, or connect it directly to chassis ground. but seriously, if you lose detail from leaving it unconnected, I would have a look at your system, because the level of CMRR should be higher than the level of your hearing. and by leaving it unconnected, I mean completely remove the shield from the cable, otherwise there will be capacitive coupling of the noise it collects; into the signal, as it wont have anywhere else to go if its there but unconnected.
Old 14th September 2010, 03:29 PM   #6
Hi Kevin,
this a subtle point to discuss. If I do not filter the noise and connect pin 1 straigth without any filtering, you are right. But I experimented solution #3 and it is a sensible improvement in resolution. Whether or not it is due to noise, I like it...
My question is indeed "which are the ferrite specs" you suggest, and also, "which configuration among #1, #2, #3 is preferable". As you can see, having no pin 1 connection or pin 1 connected to the chassis is not listed :-) Seriously, I tried them and I like them less... So I want one of #1, #2 or #3, but I do not know which kind of ferrite to choose. This is my actual question, any help is welcome :-)
Roberto
Old 14th September 2010, 04:11 PM   #7
Theoretically speaking, I agree with you. Those were my first experiments. However, practically speaking, I like more connecting pin 1 + filtering.
Just to add some more info, the pin 1 signal I'm considering is coming out from a trasfo connected to the differential output of the AKM4393 DAC chip (plus some resistors). Note that there is no electrical connection between the pin 1 of the trasfo and the chassis ground.
If I connect pin 1 of the XLR connector to the chassis ground (according to Rane notes) or pin 1 of the trasfo to the chassis ground, the sound is not bad but has more grain.
If I do not connect it at all, the sound is dull.
If I connect pin 1 of the XLR connector to the pin 1 of the trasfo, the sound is too bright and edgy.
If I connect pin 1 of the XLR connector to the pin 1 of the trasfo plus use configuration #3 to filter (according to Rane notes and Neutrik EMC ideas), the sound is great to my ears: detailed and clean but not bright. This is why I'm asking advice on this pathway.
Please note that I use active ATC SCM50ASL Pro speakers, and good quality cables, to evaluate the sound (again according to my ears).
Cheers
Roberto
Old 14th September 2010, 05:26 PM   #8
I think that you are just adding another path for noise to sneak into the analog parts of the circuit.
The filtered Neutrik EMC XLR connectors are for analog.
The filtered Neutrik XCC XLR connectors are for digital.
Kevin
Old 14th September 2010, 06:29 PM   #9
qusp's Avatar
well unless the output needs some kind of bias on the ground line to remove DC offset (not in your case with TX isolation) it is only a shield, has no connection to the output of your dac at all and should only have (indirect) connection to AC/earth ground. for the ferrites, hard to say, the only place I ever use them is on digital lines and they are 600R types, otherwise I use chokes. I wont argue with your findings, as I have had some funny business with cables before and i'm firmly in the for camp, but shield in bal audio is waaay down the bottom of my list after connector plating and dielectric, for balanced audio I never use the shield, because I see no reason to and it just adds capacitance and a path for RF that would otherwise not be there, either directly coupled or capacitively. even with ferrites and resistors you are still allowing ground currents to be at different potentials and they will therefore flow.
so yeah mate, not gonna be much good, I have used 600R FAIR RITE - 2744555576 - FERRITE BEAD, SMD, 6.2mOHM with good results in RCA cables and low noise regulators in AVCC ref supplies for dacs. you could try a choke on the 2 'good' channels too.
good luck
Old 14th September 2010, 07:44 PM   #10
I see your points. Since I'm experimenting, what if I make a compromise between your suggestions and my proposal? See the attached picture: I connect pin1 of the XLR connector to the chassis ground, and the the pin 1 of the trasfo to the chassis ground, near the trasfo itself and far from the XLR connector.
Roberto
XLR Pin 1 question - chassis vs circuit ground HeadSh0T Pass Labs 25 30th September 2010 04:20 PM
Pin configuration for XLR connectors on Adcom amps Perry Babin Car Audio 7 3rd March 2010 03:36 PM
XLR Pin#1 problem - Bridged LM4780 GAH Audio Sector 16 24th September 2009 01:22 AM
Adding balanced XLR digital output... Skorpio Digital Line Level 2 20th July 2009 02:27 PM
XLR 4pin to 3 pin male adapter kevinhero Parts 3 18th November 2003 01:09 PM
Page generated in 0.14128 seconds (82.00% PHP - 18.00% MySQL) with 11 queries
