Old 3rd January 2013, 01:54 AM   #211
AudioSan is offline AudioSan  Norway
aha. i'm not going to use a control board. it will be internal DAC for my CDpro2 player.
so what i need to do is short pin 1 and 2 to ground?
right now it's playing with my squeezbox, and its sound wonderfull
Old 5th January 2013, 04:30 PM   #212
beiji is offline beiji  France
I just have a fda 1B ( buy to a forumer for christmas) and i would like to know :
1) what is the function of the resistors 4R99 ( like R130) behind the analog out of the dac pcm1794 ?
2) I have a clock 11,286Mhz /5V from tentlabs. Can i use it with his own power supply and few modifications of the asrc card ? I want use the dac in a first time only with a cdpro at 44.1 khz.
3)Is that possible to have the schematics of the asrc board ?
bruno
Old 6th January 2013, 12:19 AM   #213
spencer is offline spencer  Singapore
Send a message via MSN to spencer
The circuit of the ASRC BD is here:
http://www.fetaudio.com/wp-content/u...7-ASRC-Ckt.pdf
Regarding clock to the ASRC, it is a 24.576Mhz XO. Not sure if you can use 11.286Mhz or not.
Old 6th January 2013, 11:39 AM   #214
thanks for your answer.
Could you confirm to me i can sold ad1896 or src4192 on the pcb ? Or you have a pcb for each ?
( I have a pcb with ad1896 write on.)
bruno
Old 6th January 2013, 03:52 PM   #215
The pcb is designed for AD1896. For SRC4192, there is no MCK out and thus the clock will be using the XO frequency. Thus the soldering is different.
Old 6th January 2013, 09:41 PM   #216
I'll try to sold together pin 2 and 3 of the src4192 and so, Mck Out will be the same of XO frequency and that would be working with your pcb.( I have one src4192 in my stock of parts but no ad1896)
and about the function of the resistor 4r99 at the entry of the I/V stage it's a secret ?
In a first time I have think this resistor is using for decrease the entry impedance of the stage i/v but on the MicroCap8 simulation, it's not the case.So I don't understand what is this function.
Old 7th January 2013, 01:42 AM   #217
Regarding the output resistors to the IV, there is someone take some measurement and analysis on that in this forum. The findings is that driving a resistor IV up to 50 ohm to ground will not increase the distortion level much.
In my case, I find that putting the resistor in will ensure the distortion will be minimum at all situations. As you can see my design is not driving the output to a virtual ground but rather a positive reference set by the diodes. After doing that, the distortion is more consistent and low. Thus the resistor effect is minimized and become just a crossover of signal. I think if you are interested, you can change the value to see if you can hear any sound difference. I did not tried all possibility as it is a very time consuming process.
Old 7th January 2013, 10:42 PM   #218
apoo is offline apoo  Germany
Has somebody interest for buying my full assembled and working FDA-1B with both ASRC boards? External i2s prepared for WaveIO, Dale i/v resistors and russian PIO capacitors. No output capacitors. Eventually a Schuro encapsulated and ground-shielded toroidal transformer 230v-2x18v 65VA. Delivery from Germany. I´ve payed for all parts, inkl. transformer 560$ / 430€. Please PM me for offers!
apoo
Old 8th January 2013, 02:31 PM   #219
I´ve forgotten to say why i´m selling the FDA-1B. Well, I´ve noticed that i personally like more the sound of a NOS DAC.
Hum in Balanced Mode in Balanzed Bride Of Zen Erlend Sæterdal Pass Labs 35 12th August 2010 09:17 PM
Help TDA 4X 1541 balanced Mode gil-garcia Digital Source 1 6th December 2007 05:12 PM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 06:36 PM
PCM1798 mono mode with balanced output help mpopovics Digital Source 8 24th September 2005 11:00 PM
Copyright ©1999-2017 diyAudio
