Old 12th February 2012, 11:42 AM   #121
zibra is offline zibra
well, if you want big improvement in SQ not just different taste of sound I strongly advise to replace 7805 regulator. I just plugged DIY discrete one and its improvement in all areas.
Old 12th February 2012, 12:02 PM   #122
TC Goh is offline TC Goh  Hong Kong
Wow. What did you replace it with? Any chance of some photos? I just dropped in a L4941 sometime ago and that made a difference too. Sounds like you are having a much higher gain.
Best wishes
TC
Old 12th February 2012, 12:14 PM   #123
Generally its complete discrete power supply made by friend of mine, without any resistors etc. Im not that good in details. For now I just plugged it straight into place of 7805 regulator. It has 2 stages of stabilizing. Its big catharsis for sound
Old 12th February 2012, 11:49 PM   #124
Hi Zabra
Perhaps it is my browser but you picture doesn't load.
Best wishes
TC
Old 13th February 2012, 01:04 AM   #125
SoNic_real_one is offline SoNic_real_one  United States
Imageshack wants it like this:
Old 13th February 2012, 08:36 PM   #126
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
I guess Salas's Shunt Reg would fit perfectly there!
Anyone tried?
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 13th February 2012, 10:04 PM   #127
Dont think anyone tried dicrete regulator here yet but improvement is crucial to sound - not just matter of taste and preference. I also tried pluggin that power supply into +20V but it sounds worse after short comparision (will try tomorrow also). If you are hardcore then discrete regulator in that place is a must and I dont focus on very subtle changes Difference is huge.
In few days Ill be also testing DIY asynchronic USB-I2S module on TAS1020B as Im using PC for music (EMU1212) so more news toshare in future. Also will try Caddocks in I/V conversion and some Amtrans and others for filtering. So still a lot for testing but that swap is already biggest improvement in SQ easily to hear even for a beginner
Old 14th February 2012, 10:51 AM   #128
UMarcus is offline UMarcus  Germany
Hi All,
i had build a pre amp dac with the boards from spencer, it sounds fantastic. I would like to express my sincerest thanks to spencer and community to provide and support such great dac.
Attached some photos of my DIY stuff and dac boards.
btw.. i upgrade the dac with HFA rectifier diods and bellson LDO..
Marcus
Old 15th February 2012, 12:55 AM   #129
pinnocchio's Avatar
Originally Posted by UMarcus View Post
Hi All,
Marcus
Hi Marcus,
What line stage are you using for the DAC? It is tubes but cannot read on the PCB...
Do
Old 15th February 2012, 01:14 AM   #130
qusp is offline qusp  Australia
qusp's Avatar
using an async usb convertor for audio production may not be the best idea unless you can set it somehow as the master clock for everything; as it adds a small (actually by production standards maybe not that small) and probably unknown latency, if you have to sync with other hardware or software mixers, ADC inputs and instruments; it doesnt work that well
Hum in Balanced Mode in Balanzed Bride Of Zen Erlend Sæterdal Pass Labs 35 12th August 2010 08:17 PM
Help TDA 4X 1541 balanced Mode gil-garcia Digital Source 1 6th December 2007 04:12 PM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 05:36 PM
PCM1798 mono mode with balanced output help mpopovics Digital Source 8 24th September 2005 10:00 PM
