New PCM1794A Kit – Balanced Mode Update – Good to Fantastic Sound! - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd October 2010, 03:18 PM   #61
sendler is offline sendler  United States
Default 2mv
Originally Posted by TC Goh View Post
Hi Scott
Hope you are having a good weekend.
The DC offset is set by 2 (5K, I think) variable resistors on each board. So far (touch wood), the offset is close to 0 with a variation of about +/- 2mV but hovers around +/- 1mV most of the time. It doesn’t vary much though, even during use (on my set, at least) but that could be because my Fluke can't detect it! Its resolution is only up to 1 mV.. Ha ha.
I think if it stays within this range, it should be ok, right? Anyway the speakers and amps are still functioning, which is always a good sign.
Oh, OCL is also slightly louder. I guess this is because this is the path of least resistance.
Best wishes
TC
2mv is excellent. Most circuits should have no problem if it stays that low.
Scott
Old 3rd October 2010, 07:58 PM   #62
Hi TC,
yes, those are line transformers. I put the two Jensen JT-11P-1 to connect the balanced output with the SE input of my DNM pre-amp.
Daniel
Old 3rd October 2010, 08:02 PM   #63
The transformers should not affect the sound too much. There is always some loss, and it would be interesting to test further transformers but at the moment I am just happy.
Old 3rd October 2010, 11:25 PM   #64
TC Goh is offline TC Goh  Hong Kong
Hi Scott
Thanks.
I guess this will need to be checked regularly like tube biases....
Having said that, there is a circult relay that should prevent DC leaks in the event of an unexpected spike.
Best wishes
TC
Old 3rd October 2010, 11:43 PM   #65
Originally Posted by c1cc1ccc1 View Post
Hi TC,
Daniel
Hi Daniel
Ah.... I am guessing here again but as you have a balanced set, the line TX are probably to step-down the output from the 3V to 1.5V, right? I actually tried using 3V output feeding my pre-amp's SE RCA and it sounded distorted probably from being overloaded!
Would the dynamic range be still at 133db? If it maxes out at this, then the TX is a wonderful addition as you get the best of both worlds!!!
Best wishes
TC
Old 7th October 2010, 06:35 AM   #66
TC
Hi TC,
not really to step-down, the turns ratio of the TX is 1:1. I need the DAC's output galvanically separated since my preamp is single-ended, so I have different grounds between the source and the sink. With the setup I let the DAC operate into a virtual ground.
I have no problems with distortions but of course there are transformers with different turn ratios that can solve this issue.
To keep the dynamic range you should place the TX as close to the single-ended sink as possible, AFAIK.
(Note that I am not an expert in the field of transformers.)
Regards, Daniel
Old 7th October 2010, 06:46 PM   #67
Default 24/96 usb to I2S converter
Hi Scott
Thanks for your reply. I will do more research on e transports.
Here are a couple new 24/96 usb converters to compete with the HiFace.
New 24/96 usb converters
Scott
Old 11th October 2010, 06:04 AM   #68
Hi Scott
Looks interesting and this seller is in HK too. That should prove convenient for me Click the image to open in full size..
Wow ...1 ppm clock! I think this should mate well with the 1794A DAC.
The seller also lists some sites where we can get high res 24*96 flies. In a capable system, the music should be great!
I will certainly take a good look at this.
Thanks.
Best wishes
TC
Old 11th October 2010, 07:33 AM   #69
Calvin is online now Calvin  Germany
Calvin's Avatar
Hi
why settle for 24/96 when You can do 24/192 already?
jauu
Calvin
Old 12th October 2010, 08:35 AM   #70
skseah is offline skseah  Singapore
Hi T C,
Finally finished my DAC...now 'burning' it in...initial sound very promising...unfortunately, one of my amp just broke down..so now have to solve the amp before I can listen to DAC. Will try to roll the caps later.
Best Regards
Hum in Balanced Mode in Balanzed Bride Of Zen Erlend Sζterdal Pass Labs 35 12th August 2010 08:17 PM
Help TDA 4X 1541 balanced Mode gil-garcia Digital Source 1 6th December 2007 04:12 PM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 05:36 PM
PCM1798 mono mode with balanced output help mpopovics Digital Source 8 24th September 2005 10:00 PM
Copyright ©1999-2017 diyAudio
