| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#201 |
Short pin 1 and pin 2 of J1 to pin 3 (ground) to have default = (0,0) or I2S as input from J5. Short R171 to un-mute the I2S input or use the pin 9 of J5 to control the mute from external source. Mute is active High.
#202 |
exelent
maybe i have to get this dac then and use a 3U chassis.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#203 | |
The best caps are NO caps :-) I´m listening to FDA-1B OCL! After one week of burn in, just shorted the output caps an set DC offset to 0mV (+-1mV). Sounds great, more focus and more 3D! apoo |
#204 |
No caps and the daughterboard with the TI chip. That's what I am using for critical listening. Worth every penny!!!
![]() cheers rec. |
#205 |
Hi folks,
i was very impressed of the dynamics of this DAC from very beginning, but the sound was after a short time of listening fatiguating. I´ve changed the i/v resistors with dale resistors and PIO capacitors K40Y-9. This was better but not enough. I decided to try batteries. These are the changes: - OCL! all output caps shorted, DC offset adjusted to 0mV - analog supply PCM1794A - two separate belleson +5v reg with LiFePO 2x3,3v - digital supply PCM1794A - two separate LiFePO @3,3v - a huge improvement in sound was the battery supply for the discrete IV! 4x24v lead-acid batteries - 12v lead-acid for the receiver The WaveIO USB receiver (XMOS) i´m using is also fed with 6v lead-acid and a 2A-5V belleson reg. The onboard isolator with 3,3v LiFePO The change is huge! It´s another DAC! It´s not fatiguating at all, it has tremendous dynamic and the treble is not so "hi-fi" like. Bass is very, very controlled and deep. It´s maybe the best DAC i´ve heard for a long time! Give it a try! |
#206 |
Add a RX-V8 interface board for Amanero Combo384 to FDA-1B and FDA-2A. Details can be found in below link:
RX-V8 Interface Board from “Amanero USB-I2S module” to FDA-1B or FDA-2A DAC |
#207 |
hey. i've got the FDA-2 from you, and soldered it an tested it now. i guess this is the same for FDA-2 as for FDA-1?
#208 |
See J5 table:
#209 |
J5 is all good. i was thinking of J1. just short pin 1 and 2 to pin 3?
#210 |
Pin 3 is also an input pin for FDA-2. Pin 3 can be short to ground using R97 (default become 0 = ground).
When R97 is shorted, then short R107 and open R106 to have same function as FDA-1B. FDA-2 is more flexible to have 5 input or 4 input and thus jumper(or resistors) need to be set properly. Of course a new control board is required. |
| Hum in Balanced Mode in Balanzed Bride Of Zen | Erlend Sæterdal | Pass Labs | 35 | 12th August 2010 08:17 PM |
| Help TDA 4X 1541 balanced Mode | gil-garcia | Digital Source | 1 | 6th December 2007 04:12 PM |
| Anyone used a PCM1794A with balanced output? | hifimaker | Digital Source | 11 | 18th March 2006 05:36 PM |
| PCM1798 mono mode with balanced output help | mpopovics | Digital Source | 8 | 24th September 2005 10:00 PM |
