New PCM1794A Kit – Balanced Mode Update – Good to Fantastic Sound! - Page 12 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 30th January 2012, 03:16 PM   #111
TC Goh is offline TC Goh  Hong Kong
Hi Zibra
I haven't personally but I do share your view that the choice of regulators do affect sound. Perhaps you can try using a LM317T regulator too. I know these do sound a little faster and with more punch. Also, they are cheaper too
It should be interesting... Keep us posted as to whay you decide to do...
Best wishes
TC
Originally Posted by zibra View Post
Anyone of you tried other regulators than those 2 mentioned at documentation? Im thinking of replacing it by some kind of discrete regulator like supertedddyreg, DEXA etc.
Any hint? Im really curious for resyult and which one to choose? Also do you believe it will change sound for both Cirrus and PCM? Anyone tested it?...
Old 30th January 2012, 03:21 PM   #112
spencer is offline spencer  Hong Kong
Send a message via MSN to spencer Send a message via Skype™ to spencer
Sorry, LM317 is not direct replacement for TA7805 in FDA-1.
Old 30th January 2012, 03:33 PM   #113
Hi Spencer
Of course you are right. Sorry for not being clearer but I think Zibra may be aware of this.
Best wishes
TC
Old 30th January 2012, 03:43 PM   #114
Yeah, I will post my observation. Actually friend of mine is preparing DIY regulator for me. Something like Teddyreg without any resistors. Ill try to make as clean power as possible
Already tried Rubycon ZA instead of Silmic for PCM power supply and found it better without somewhat bloated bass in comparision.
I will be also experiencing with another filter capacitors instead of Russian ( ordered silver mica, amtrans and polystyrene) and conversion resistors (Caddocks).
Spencer made great dac. No doubt about it. You can just buy it, plug it and forget it However for hardcore and curious modders its great field for experiencing and achieve even more nirvana)
Strong recommendation for that dac!
Old 30th January 2012, 04:09 PM   #115
jambul is offline jambul  Belgium
dear spencer,
Have you try to used the asrc/multi rate freq or using external clock as master clock?
Denis
Old 30th January 2012, 05:34 PM   #116
arupg is offline arupg  Latvia
I would be very keen to compare the full-scale FDA with my reference setup, i.e. [metronome kalista ref + accuphase dc-801] vs. FDA (yeah! its totally unfair from the monetary point-of-view) but nevertheless I just wanna see where things stand ...
And as Zibra correctly points out, Spencer's FDA is excellent as standalone but there's room for lots of experimentation to change & suit the flavor for an individual's system, music & taste ... which is by itself a superb feat !!
Voila ! ...
Old 31st January 2012, 08:11 AM   #117
I guess the next mod, if the results of the digital side are +ve, will be the I/V ones... Whoa ….. That will get very interesting.
I googled Teddyreg and I think they are using the standard LM317 too. This should be a very interesting experiment.
The Silmics are a very interesting e-cap. Apparently, it uses natural fibers (Silk?) in its construction. In my system (all tubes), the Silmics actually improves the bass volume, albeit, with a little less control, as you have observed. Maybe I should try some OSCons.
I do second you in saying that Spencer made a great DAC. This DAC is already capable right out of the gate (Silmic, Dale, Russian PIO and all) but can be 'customized' to a degree to match the rest of the system to arrive closer to the individual’s musical taste. I guess this is what drives passionate (aka crazy!!!) Diyers.
Keep us posted, please ...
TC
Old 31st January 2012, 08:32 AM   #118
Wow!!!
A 59 kg transport (that looks like moon base alpha) with its isolated 5 battery pack and 8 regulators PS feeding the FDA-1!!!! Talk about Goliath and David!!!
I am speechless ....
Anyway, it will be an interesting, albeit and unfair one, comparison between the DC-801 and the FDA.
TC
Voila ! ...
Old 1st February 2012, 12:47 AM   #119
pinnocchio's Avatar
Default Critical resistors
Can anyone point out what are the really critical resistors. I'd like to try changing those to TX-2575 once I buy the DAC...
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA2 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 1st February 2012, 02:59 PM   #120
I believe Spencer uses Dales for most resistors in the signal path and he once told me that the critical I/V resistors are the 475ohms at locations R1, R2, R18, R19.
On a different set up, I compared the Dales to Welwyn's Metal film precision 0.25W,0.1% resistors. They sound clearer (more analytical) but not as warm.
Trade offs, I guess...
Best wishes
TC
Hum in Balanced Mode in Balanzed Bride Of Zen Erlend Sæterdal Pass Labs 35 12th August 2010 09:17 PM
Help TDA 4X 1541 balanced Mode gil-garcia Digital Source 1 6th December 2007 05:12 PM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 06:36 PM
PCM1798 mono mode with balanced output help mpopovics Digital Source 8 24th September 2005 11:00 PM
Copyright ©1999-2017 diyAudio
